Old 07-13-2004, 02:12 AM   #1 (permalink)
wmedia's Avatar
Date registered: Jul 2003
Vehicle: 1998 S280
Vibrations in steering wheel
Not very exciting one this, but I have been getting vibrations in my steering wheel between 50-60mph. I got the tracking and wheel balancing done, but I'm still getting this "twitching" in the steering. It's really noticable if I let go of the steering.
The front tyres are worm unevenly as the tracking was originally way off. Could it be a lingering effect of the uneven tyres?
Cheers.
wmedia is offline   Reply With Quote
Old 07-13-2004, 03:01 AM   #2 (permalink)
Date registered: Dec 2003
RE: Vibrations in steering wheel
did you get 'tracking' done or proper 4 wheel 'geo check' or geometry check. these cars are v sensitive to alignment - its not just the tracking (in / out of the front wheels) but also the caster / camber etc of all four wheels that needs doing.
theres a BIG difference (jn price as well... [:(] ) between 4 wheel alignment / tracking and a geo check (100+ quid)
could also be the steering damper (easy replacement)
but v likely to just be residual from knackered tyres.
guydewdney is offline   Reply With Quote
Old 07-14-2004, 02:36 AM   #3 (permalink)
wmedia's Avatar
Vehicle: 1998 S280
It was only the front wheel tracking, not the full geometry check.
Wouldn't steering vibrations be wheel balance related, rather than tracking though?
I'm wondering if it'll settle down once i've re-worn the tyres a bit, but that might be wishful thinking!
Old 07-14-2004, 11:30 AM   #4 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
Not a sensible thing to do, see if they settle down . your steering damper might be shot, they are quite cheap and easy to fit. try changeing your wheels right front to back left and left front to back right see if it helps, otherwise is going to be replace the damper first then other parts
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 07-14-2004, 01:59 PM   #5 (permalink)
Tricky's Avatar
Date registered: Feb 2004
Vehicle: 1992 600 SEL
Hi,
Strange i got exactly the same thing right around the 56-58mph range.
Got new tyres n balanced, not tried wheel alignment though.
Could it not be bushes as well?
Tricky is offline   Reply With Quote
Old 07-15-2004, 02:21 PM   #6 (permalink)
Merc600sec's Avatar
The easiest way to check is with a Magnetic Dial Guage.. mount it in the wing above the wheel , with the front elevated , check to see if you have any run out.. then with it on the floor roll it back and forth one +half a revolutions any deviation will indicate you have a prob
Old 07-22-2004, 06:37 AM   #7 (permalink)
wmedia's Avatar
Vehicle: 1998 S280
Right, well, I got some new tyres put on the front, rebalanced etc, but still getting the vibrations. If anything they're worse now (probably due to more tread?)
Time to check the bushes/damper etc I think. I'm out of ideas otherwise!
Old 07-22-2004, 09:25 AM   #8 (permalink)
~BANNED~
Date registered: Jul 2004
Vehicle: 98 S500
I was having this same nagging problem with my 98 S500. On brand new tires, I took them back and had them rotated and re-balanced, but steering wheel shimmy did not go away.
I took it back to the tire shop once again, this time they "load balanced" all 4 wheels/tires. Apparently the 2 back tires were poorly mis-matched to the wheels, where the tire needed to be rotated on the wheel about 90deg or so.
A re-check after adjustment gave a much better balance figure, and I've been testing it over the last few days. I'm afraid it did not fully go away however, but it is much better.
I'm off to the parts dept for a steering damner (shock absorber), the local dealer wants $65.00(us) for one. I've seen them online for $35 or so, but must add shipping of course...
inetd is offline   Reply With Quote
Old 07-28-2004, 07:03 AM   #9 (permalink)
wmedia's Avatar
Vehicle: 1998 S280
If anyone is interested... Just got car back from Merc specialist, and it was the anti roll-bar rods. The connections were worn. Also the front brakes were sticking. Drives much better now.
I'm so pleased I found a specialist rather than using the Mercedes shop! Didn't cost much to fix.
