I've been searching for technical details on the operational aspects of the hydraulic shocks on my 1995 S600. There is a lot of conflicting info out there. Does the power steering pump supply the pressure for the shocks, or is there a seperate pump? I know there are two seperate reservoirs for these systems, but that's all I'm sure about. I would really appreciate a knowledgeable person to bring me up to speed on how these systems work.
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
In cars with the self-levelling suspension and ADS, etc. (standard on 600's)
the power steering and ADS system run off what is called a tandem pump. It is two separate pumps built into a single housing that run off a single pulley driven by the poly-rib belt. The pumps run two separate hydraulic circuits with different fluids for power steering and ADS/self-levelling. The power steering reservior is located right on top of the pump housing located (it appears from some curtailed diagrams I have access to) on the left hand side (US driver's) of the engine. The suspension reservior is located just forward of and above the left wheel well with a removable hatch in the plastic cover specifically for access to it for filling.
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
RE: What pressurizes the hydraulic shocks?
Did some pics on this on my gallery, the shocks suspen sys has a filter in the resevoir, and one on each rear shocker .
the filter in the res is a magnet and gauze. if it is black you may have some probs.
If you've GOT to have a extension,
Have a BIG one.
Nice gallery Merc600sec! Your pics illustrate the system nicely. When I checked the oil, a minimal amount registered on the dip stick. I'm not sure if the reservoir was empty, or just barely full. I put in about 1/2 liter to get the fluid level to the mid mark on the dip stick. Is it possible that there is air in the system? If so, how can I tell? I seem to remember seeing an article stating that this system needs to be bled if air gets in it. Do you think this is necessary? How is this done?
