» Site Navigation
» Other Sites
Old 06-26-2004, 11:48 AM   #1 (permalink)
drebdy's Avatar
Date registered: May 2004
Vehicle: W140 S600 300D300SD
Send a message via Yahoo to drebdy
how to check engine oil level and tranny ?
hello folks, i just want to know what's the best way to check the engine oil and tranny atf fluid levels, what i usaully do is every morning i would check on the engine oil dipstcik and check the level, if the level is below full iadd oil, is my method of checking the oil proper?
re: tranny fluid level, i usually check it after using my car and then i pull out the dipstick while the engine is idling and th etranny is in park, is this correct procedure?
thsnks in advance,, :)
drebdy is offline   Reply With Quote
Old 06-26-2004, 12:29 PM   #2 (permalink)
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: how to check engine oil level and tranny ?
thats the correct way m8 but better done with engine a normal operating temp and on level ground[:)]
teky is offline   Reply With Quote
Old 06-26-2004, 03:28 PM   #3 (permalink)
barry putnam's Avatar
Date registered: May 2003
Vehicle: 1995 MB S320V: 2006 kawasaki vulcan 900 lt
You are overdoing it a bit buddy. No reason to check daily, if your engine is suffering that great an oil loss to be topped up daily it has a significant problem.
Secondly there is no need to keep it right up to the full mark on the dip stick. Engines differ in the level at which they equalise the oil level, some are stable at full, others at 3/4 full, or 1/2 full indicated on the dip stick. The dip stick only tells you that you are down 1/4 or 1/2 a litre, no need to stress, you still have 9 1/2 liters left.
Remember the add mark is there to tell you when to add, so kick back and relax till then.
Barry
BECAUSE SIZE REALY DOES MATTER, W140
barry putnam is offline   Reply With Quote
Old 06-27-2004, 10:39 AM   #4 (permalink)
drebdy's Avatar
thanks barry, i do the check up every morning on my 1985 300SD and my '85 300D-T, those are really old cars just to make sure, but now that u told me i'l take it easy and just do the checking once a week, As for my S600, i check it once a week, it doesnt show any sign of oil lose, i envy ur car, before i got my S600, i was looking for an s320 but it wasnt available in the shops here, ur car is easier to maintain and of course the mpg's are really good, mine's got 12mpg only its really a thirsty car, i hjav e to take it easy on the gas pedal or else i'l just get 10 or even 9mpg,
