View Poll Results:
0%
Voters: 0. You may not vote on this poll
Old 06-01-2004, 12:14 AM   #1 (permalink)
AL-Sayegh's Avatar
Date registered: Feb 2004
ABS ETS Help
I got ABS and ETS Lights in my instrument panel . []Brakes is Good any help to determine this Fault Thanks.
1995 S320
AL-Sayegh is offline   Reply With Quote
Old 06-01-2004, 02:05 PM   #2 (permalink)
Date registered: Jan 2003
Vehicle: W140 S300 TD
RE: ABS ETS Help
Plenty of answers in this forum.
Perhaps a sensor or a box above the gas pedal.
steph is offline   Reply With Quote
Old 06-02-2004, 08:49 PM   #3 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
RE: ABS ETS Help
Probably the brake pedal switch. Another common is the switch at the accelerator pedal. Give symptoms if any. If you have no symptoms, it's probably the brake pedal switch...
BENZDOC is offline   Reply With Quote
Old 08-26-2004, 05:33 AM   #4 (permalink)
AL-Sayegh's Avatar
RE: ABS ETS Help
Hi all, I have changed the brake pedal switch. The mechanical said that he caned access the ABS system through the Smart Scan the Switch cost me $ 25 but the light extinguished just for one second and returned back. the mechanical then tell me that there is fault in the electrical system and the replacement switch is damaged to . so he is doing the checking to all the electrical wiring which will cost me about $ 1000 . to find what causing the problem. I return back home very sadly and disassemble the switch which he relapsed it But found it just push switch and there is nothing damaged in side it or any sine of burning material ?? any help argent.
Old 08-26-2004, 06:59 AM   #5 (permalink)
loveit_hateit's Avatar
Date registered: May 2004
Vehicle: '95 S320
RE: ABS ETS Help
Have you ever had the main wiring harness replaced? That year 140 had a factory harness designed to be biodegradeable. The only problem was that it degraded much quicker than MB expected I think. Anyway, they usually need replacing within the first 7 or 8 years of life. To my knowledge, the replacement harness does not have the degradeable feature. I also have a 95 S320 and I had to replace a couple of years ago. This will cause all kinds of electrical mishaps until you replace it. It is very expensive from the shop, I paid around $1800 because it did some other damage as well before diagnosed. What happens is the insulation around all of the wires that are bundled in the harness desintegrates leaving all the wires in the harness to short against one another. This may be your problem. There are other threads in this forum that show pictures. Just search on wiring harness.
loveit_hateit is offline   Reply With Quote
Old 08-26-2004, 01:10 PM   #6 (permalink)
mercS600's Avatar
Date registered: Nov 2003
Vehicle: S600L
RE: ABS ETS Help
Just had my wiring harness in my 600sel replaced for the same reason.I couldn't believe the state of the wiring!For my 600 the harness was £328 and took approx 30min's to fit at my main dealer.For the 600 the part number is A140 540 47 05.[:0][:)]
mercS600 is offline   Reply With Quote
Old 08-26-2004, 02:22 PM   #7 (permalink)
AL-Sayegh's Avatar
RE: ABS ETS Help
Thanks loveit_hateit and mercS600 I’m still waiting for my electration to find the matter he believed that there is a shortage in the central lock especially where this problem is appear just after replacing the center lock motor , Because it got burn .
