Old 05-29-2004, 11:27 PM   #1 (permalink)
Date registered: May 2004
On a '96 S420, what is...
...that cylinder hanging by foam pads just next to (towards the rear) of the mono-valve? It seems to have a vacuum line connected to it. Every now and then, while working under the hood, I noticed that it "clicks" continuously and rather noticably, like a broken relay. I'm thinking a some sort of pressure monitor/switch?
ninjamonkey is offline   Reply With Quote
Old 05-30-2004, 01:21 PM   #2 (permalink)
Date registered: Dec 2003
RE: On a '96 S420, what is...
pic?
had a look on the epc - looks like it might be a control valve for the vents auto open / close...
guydewdney is offline   Reply With Quote
Old 05-30-2004, 09:02 PM   #3 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
Sounds like the purge valve for tank ventilation.
BENZDOC is offline   Reply With Quote
Old 05-31-2004, 03:23 PM   #4 (permalink)
Purge valve? Is it supposed to click like that?
This is a view from the front driver's side -- this is under the front plastic shroud:
Old 05-31-2004, 03:55 PM   #5 (permalink)
does it click only with engine running?
does it click with air con off (ec light on?)
does it still click with all ventelation off?
can you get a part number off it?
had a look - def not the vacuum system
not heating ventelation as far as i can see.
could be (as mentioned above) fuel thingy - so:-
140 470 00 93
000 470 20 93
000 470 15 93
are all the same part (the first was replacedc by 2nd which in turn replaced by 3rd... - obv cocked up design....)
Old 05-31-2004, 08:41 PM   #6 (permalink)
ninjamonkey - 5/31/2004 5:23 PM
yes it clicks when the engine reaches operating temp. Thats why it's mounted in rubber mounts. It gives the tank pulsed vacuum instead of continuous. Tampering will trigger the check engine light and store codes.
