Old 05-28-2004, 09:28 AM   #1 (permalink)
Date registered: May 2004
Vehicle: 87 560, 89 Porsche 928S4, 93 300TE
1996 S420 Timing Chain Replacement
The timing chain broke - had to send heads to machine shop and had 6 valves replaced.
Replaced two of the cam sprockets and also drive shaft sprocket - the rails were good,
and replaced the tensioner, in fact the tensioner does not want to go in all the way.
For some reason the chain is too tight after installing the tensioner - we thought that the
chain may be bunching up in front of, or in back of the crank - took off the pan and inspected visually.
Have tried two new factory chains and get the same results. The engine starts and runs fine but will chew
the sprockets in a short time due to tight chain.
Mercedes tech support says that this problem is unique and has not occured to others.
Has anyone seen this problem installing a new chain? Original chain broke at 53k. Thanks for any input.
HankL is offline   Reply With Quote
Old 05-28-2004, 10:54 PM   #2 (permalink)
barry putnam's Avatar
Date registered: May 2003
Vehicle: 1995 MB S320V: 2006 kawasaki vulcan 900 lt
RE: 1996 S420 Timing Chain Replacement
Sounds like the tensioner may be the wrong size, or incorrectly installed, if the chain is too tight after the tensioner is installed.
Barry
BECAUSE SIZE REALY DOES MATTER, W140
barry putnam is offline   Reply With Quote
