Old 05-27-2004, 05:11 PM   #1 (permalink)
bouzouki's Avatar
Date registered: Nov 2003
Vehicle: 1995 MB s320
Send a message via AIM to bouzouki
oil change and brakes
hey everyone, got another question for ya.......to do my oil change, do i need any special tools or instructions?? i have done on american cars, but never on my benz...... i know where the filter is, but not the drain plug....95 s320....also, i need to do my brakes, i think the front ones, are they a lot different than american ones??? and what is the deal with the sensors on the brakes....and also to let you guys know, i am taking the benz baby in for a checkup on the tranny because of that smoke i had the other day, they are charging me 98 bucks to check it out, is that a lot or cheap??? i have never taken it to mb to get it looked at or serviced....thanks for your info in advance
Laz
bouzouki is offline   Reply With Quote
Old 05-28-2004, 12:33 AM   #2 (permalink)
S-300TD's Avatar
Date registered: Jan 2004
Vehicle: S 300 Turbodiesel
RE: oil change and brakes
I always go to the MB shop for oil change. They don't drain it, but suck it out, which is considered the best(most effective in taking out all oil) way by Mercedes-Benz. I always bring my own (fully synthetic) oil + filter (original MB, from Ebay), no problem for them, they charge about 20 mins labour for this!
Seems most convenient for you too... in order to reach te the drain plug you have to dismantle the plate (mounted for better airodynamics) under the engine. Not a happy thing to do under a 2,000 kg car.
S-300TD is offline   Reply With Quote
Old 05-28-2004, 01:43 AM   #3 (permalink)
Rainmaker's Avatar
Date registered: Aug 2003
Vehicle: BMW E36, MB W140
I have a S320, the drain plug is on the side of the oil pan (directly under the engine). I just jack the car under the frame with a block of wood to not dent the frame.
See attached pic:
Rainmaker is offline   Reply With Quote
Old 05-28-2004, 01:48 AM   #4 (permalink)
Rainmaker's Avatar
To remove the oil filter, you need to get one of those "wrench adapters" (3" or 74-76mm) from autozone or walmart. You need it to remove the lid of the oil canister, in order to remove the filter element inside.
Old 05-28-2004, 01:50 AM   #5 (permalink)
Rainmaker's Avatar
The filter canister is located against the firewall on the driver side:
