Old 05-26-2004, 05:55 PM   #1 (permalink)
Date registered: Apr 2004
Vehicle: W140/JagVDP
Battery Disconnect "Problems" NOT
In an attempt to reset the "check engine" light, I disconnected the battery. On reconnect, the windows didn't work, radio had to be recoded, seats lost settings.
Turns out, if you keep tapping the window switches and don't go past the first stop (a light resistance before the button is completely depressed) the computer will relearn the auto up and down and hold settings. Keep tapping, then hold…Even if nothing is happening, it will work.
After entering the five-digit code for the radio, the first digit will start blinking, press the “SC� scan button.
Seat Memory: Before moving your seats, press memory and number you want to program.
Hope this will help newbies and others.
Pewhipadus = Name of a Greek God (Who's been married too long.)
Pewhipadus is offline   Reply With Quote
Old 05-27-2004, 02:27 PM   #2 (permalink)
AL-Sayegh's Avatar
Date registered: Feb 2004
RE: Battery Disconnect "Problems" NOT
Thanks Pewhipadus
AL-Sayegh is offline   Reply With Quote
