Old 05-24-2004, 04:24 AM   #1 (permalink)
S-300TD's Avatar
Date registered: Jan 2004
Vehicle: S 300 Turbodiesel
Tour de France
Last sunday made a 1368 km tour Holland-Belgium-France (west->east)-Luxembourg-Germany-Holland. On A26, played around a bit with an UK registered Ferrari F355 gts. We hit 190kmh now and then, but only briefly. My cruise control was at 160 kmh. He was bit more carefull, so finally he disappeared behind me. Normally, my 177HP diesel is no match of course. By coincidence, French fuelprices included!!!
Notice the beauty of the A4 Motorway. The stain in the pic is from an unfortunate, mis-calulating bird hitting my windscreen...
Then, half an hour later... panic! Four lamps lit simultaneously: ASR/BAS, ABS, brakelining and parking!! Speedo and RPM dropped to zero, no more engine power!! At a perfect moment: a large highway intersection!! 500 km from home!! After one minute of "Can-bus deliberation" only the ASR/BAS remained on (photo), and the car drove on. After refuelling in Luxumburg with engine restart, also ASR/BAS lamp went out. No further problems going home. All ok now, I hope! Perhaps all caused by the infamous brake-light switch, mentioned on the forum? It is the first time of any electronic "failure" on my car.
Jean-Paul
S-300TD is offline   Reply With Quote
Old 05-24-2004, 02:55 PM   #2 (permalink)
AL-Sayegh's Avatar
Date registered: Feb 2004
RE: Tour de France
Like the Ferrari
Is it the ETS Light comming ON ?????
AL-Sayegh is offline   Reply With Quote
Old 05-24-2004, 04:31 PM   #3 (permalink)
S-300TD's Avatar
ETS light
I am not sure what ETS means; on my car there is no light with inscription "ETS".
In my car, as described, the BAS/ASR light continued burning. It's an abbreviation from the following German technical expressions:
BAS means: Brems-Assistent (english: brake-assistant)
BAS applies maximum braking pressure instantly, when it detects the brake pedal is pressed down at high speed.
ASR means: Anti-Schlupf-Regelung (english: anti-skid-adjustment?)
ASR detects when a wheel is about to start spinning, then the brake of that wheel is applied, and engine torque reduced.
Also exists (more expensive, not on my car, today standard on all MB's): ESP
ESP means: elektronisches-Stabilitäts-Programm (english: electronic stability program)
ESP corrects under/oversteering of the car
Old 05-25-2004, 02:42 PM   #4 (permalink)
Date registered: Jan 2003
Vehicle: W140 S300 TD
RE: Tour de France
ASR replaced ETS since (almost) June 96.
It's a more efficent system, for the same function.
Try to send a french article on this subject.
steph is offline   Reply With Quote
Old 05-27-2004, 01:50 PM   #5 (permalink)
RE: Tour de France
ETS & ASR
la «S» embarque désormais de série la régulation antipatinage ASR. en lien et p1ace du contrôle de traction ETS. Le premier dispositif est plus évolué que le second en ce sens qu'il opère sur toute la gamme de vitesses via l'ABS (pour retenir la roue motrice qui cire) et l'alimentation (fermeture du volet d'air pour réduire le couple moteur). L'ASR stabilise le véhicule lorsque celui-ci tend Ã* prendre une trajectoire précaire ou, Ã* tout le moins, abordée un peu vite. Mais il n'agit pas sur les roues avant comme l'«anti-sortie de route» ESP. L'ETS, lui, se limitait Ã* assurer une simple aide au démarrage sur sol glissant en recourant aux capteurs de l'ABS; Mercedes renonce Ã* en équiper la gamme «S» pour lui préférer l'ASR, histoire de rehausser d'un cran la sécurité active du modèle.
Can't translate Sorry.
Old 07-25-2004, 03:45 AM   #6 (permalink)
Date registered: Jul 2004
Send a message via Yahoo to pat1
RE: Tour de France
[:)]Hi Jean -Paul love your s300td!!.
How's the vacation going so far?, How are the roads ect... hope to hear from you upon your return. I'm at the follow e-mail tipicrib@yahoo.com take care.
Send more pictures if you have any!! thanks.:-)
pat1 is offline   Reply With Quote
