Old 05-11-2004, 08:23 AM   #1 (permalink)
Date registered: May 2004
HOW CAN DIY , MOTOR ,MOUNT,S
HELLO, CAN ANY ONE EXPLAINE HOW TO INSTALL MOTOR, MOUNT ON A 1994 S/420 W-140 ENGINE,, ANY HEL WILL BE GREATFUL,,,, MY CAR HAVE 202,00 MILE,S ON IT NOW AND THE MOUNT,S HAVE NEVER,, BEEN CHANGE,,, THAN,S IN,AVANCE,, MELDWYER 94 S/420
mel dwyer is offline   Reply With Quote
Old 05-11-2004, 01:52 PM   #2 (permalink)
lcmlee's Avatar
Vehicle: 400 SEL
RE: HOW CAN DIY , MOTOR ,MOUNT,S
Out of curiousity...What are the reason for changing motor mounts?
- What are the signs that you need new motor mounts? Does the car shake?
- How can we tell we have worn motor mounts?
- Do we just change them just becuase of mileage or age?
lcmlee is offline   Reply With Quote
Old 06-16-2004, 08:38 AM   #3 (permalink)
pcmaher's Avatar
Date registered: Jun 2004
Vehicle: 1995 S600 (sold)
Not sure about a V8 motor, but on my V12 it was time-consuming. You cannot see if the motor mounts are damaged while they are in the car because of the heat shields on top of the motor mount. Not a good design, there should be some visual way of telling. Things that have to come off (at least on the V12) to get to the mounts...
1) Air filter intake scoops.
2) Air filter housing assemblies.
3) Mass flow air sensors.
4) Oil dipstick tube, remove fastener at opening, and remove bolt down by pan. Still cannot remove the tube, but at least it can rotate enough to provide the necessary clearance.
5) Coolant overflow hose.
6) Radiator fan shroud.
That's all I can remember for now. NOTE! The oil pan is not as stiff as old American oil pans. Even though I used a 2 x 4 on top of my floor jack to protect the oil pan, it still bent slightly. It would be a good idea to cut a close-matching piece out of 2 x 8 or 2 x 10 for better support. I also had to grind down the height of a 17 mm socket to get to the top motor mount bolt. Once the bolts were removed, the mounts came out pretty easy. You will have to turn the front wheels to get the steering linkages out of the way. BE CAREFUL, the mounts are a funky shape, and will fall out without warning even if they seem to be stuck in place. Once the old mounts were removed, it was obvious that they needed replacing. The inner portion on both mounts was sheared from the outer portion. It's no wonder I felt vibration at idle. I also marked the oil pan to get a height indication. I looked at it after I got the new mounts in, and the motor is at least 1" higher than before. The engine idles so much smoother now, you can hardly feel it running now. My car has 127,000 miles on it. Since your car has 202,000 miles on it, I can just about guarantee that your motor mounts are shot.
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
LONG LIVE THE W140!
Visit my Web Page at http://v12uberalles.com
pcmaher is offline   Reply With Quote
Old 06-16-2004, 08:15 PM   #4 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
2 ways on the v/8's. 1st, if you cant get the oil filter cap off (hit's frame rail), mounts are needed. 2nd, upon acceleration, you feel a boomp. thats the mount at it's saftey point. 6 cyl are easy, v/8's are difficult as the 12's. a lift makes it a lot easier.
BENZDOC is offline   Reply With Quote
Old 11-02-2008, 05:33 AM   #5 (permalink)
roadster49's Avatar
Date registered: Nov 2007
Vehicle: 1997 Mercedes S500 Coupe
I need to change mine as the oil filter cannot be removed.
Does anyone have PICs on changing the mounts? How hard is it? Can this be done with jackstands?
roadster49 is offline   Reply With Quote
Old 11-02-2008, 09:38 AM   #6 (permalink)
Haku's Avatar
Date registered: Nov 2006
Vehicle: 1996 S320 Carlsson Obsidian Black
Send a message via MSN to Haku
Also if there are any people out there with info on the M104 mounts also would be appreciated.
~ 1996 S320 ~
19" carlsson/lowered/crystal LED tails/crystal LED side markers/crystal indicators/S600 walnut steering wheel/S600 grille/anthracite black interior/sunroof
Haku is offline   Reply With Quote
Old 11-02-2008, 01:18 PM   #7 (permalink)
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1991 400 SE
http://www.benzworld.org/forums/w140...lacements.html
1991 W140 400 SE
1973 W115 200
Eirik 400 SE is online now   Reply With Quote
