Old 04-12-2004, 06:00 PM   #1 (permalink)
Date registered: Dec 2002
Vehicle: '92 500sel
'92 500SEL Power Steering Hose
Can anyone help out with the Part Number of the High Pressure Hose that comes out (or goes to) the Power Steering box? I guess this is the same unit that feeds the Hydraulic suspension (load leveling?) system.
The leak (about 1 quart a month) appears to be seeping out of the front section of the hose assembly, where the threaded metal fitting is crimped onto the rubber hose. It's directly inboard of the driver's tire and slightly aft (behind) the pump reservoir.
I'm almost sure there's no repairing this item - it'll have to be replaced, but I can't bear the idea or the cost of taking it to a dealer. I'm sure we can replace the item for much less somewhere else.
Comments, suggestions?
mb_500 is offline   Reply With Quote
Old 04-12-2004, 06:15 PM   #2 (permalink)
Date registered: Jul 2003
Vehicle: 92 400se
RE: '92 500SEL Power Steering Hose
Hi mb_500, I'm having the same problem with my car.
I'm going to order my part from www.*.com
They have OE parts, at very good prices!
I've ordered from them before try them out.
Just go to the site and put in your make and model, it will find the correct part for your car. Or you can call the 800 number listed on the page for help.
Let me know what happens, maybe we can swap fixes since we have the same year MB.
drk. grn. 400se is offline   Reply With Quote
Old 04-12-2004, 06:21 PM   #3 (permalink)
Vehicle: 92 400se
Sorry......
[url]http://[www.*.com/url]
Old 04-12-2004, 06:24 PM   #4 (permalink)
Vehicle: 92 400se
ok i don't know how to make this thing take the web address so just fill in the www (.) before (*) and the (.)com
Old 04-17-2004, 07:53 PM   #5 (permalink)
chuckindetroit's Avatar
Date registered: Jun 2003
Vehicle: 1986 560SEL, 1986 560SEL, 1992 500SEL
The high pressure hose should be 140 466 01 81. There is also a hose called Pressure Expansion, part number 140 320 14 72, that runs down about 6" and then toward the rear about a foot. It connects to the pump close to the high pressure hose and could also be a leakage source. I am not sure of its purpose but it is called out in my exploded view.
chuckindetroit is offline   Reply With Quote
