» Site Navigation
» Other Sites
Old 11-08-2003, 03:08 AM   #1 (permalink)
Date registered: Nov 2003
Vehicle: 560 sel
pulsing lights (help a newbie)
help?
my 1989 560sel has an odd problem.
there seems to be a voltage pulse when running.
the lights seem to pulse or flicker the fuel pump sounds like it is pulsing at the same time and the alternater makes a noise at the same sort of pulse rate. the engine also seem to "miss" at the same pulse rate.
any ideas to help a newbie to this forum[:(]
Neil Bainbridge is offline   Reply With Quote
Old 11-08-2003, 05:08 AM   #2 (permalink)
Vehicle: 560 sel
ive just take the fan belt of and the pulse problem disapeared. checked the voltage regul...
checked the voltage regulator bushes one is a lot more worn than the other but they seem ok ish
any else had a problem like this
