Old 11-01-2003, 08:40 PM   #1 (permalink)
rramsa01's Avatar
Date registered: Sep 2003
Vehicle: 98 SLK230/02 Audi A6/2007 Sport Trac
Engine Timing issue
Hi All
I found myself in nice pickle this time, I was trying helicoil a cyl head bolt hole( this is causing a valve chatter (due the camshaft being loose)and managed to get the camshaft and crankshaft timing chain spockets out off sync, there a couple marks on the chain and the spockets but they do not align up, I really need some help with this, as the Haynes Manual I am using has very limited information and/or directions.
Thanks in Advance.
rramsa01 is offline   Reply With Quote
Old 11-02-2003, 11:00 PM   #2 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
If you still need help, respond to this....
BENZDOC is offline   Reply With Quote
