Old 11-01-2003, 04:27 PM   #1 (permalink)
Date registered: Jun 2003
Vehicle: 1982 380 sel
bad key ignition barrel
82 380 sel The key will not turn, windows are down I need to change the hol darn thing can anybody tell me how is this done please. thanks
Ricardo Garrigosa
majestic is offline   Reply With Quote
Old 11-02-2003, 11:06 PM   #2 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
It's a long process, so if you still need it , respond to this. In the meantime , power ...
It's a long process, so if you still need it , respond to this. In the meantime , power the two fuses in the fusebox (rf & lr,lf & rr)with a jumper wire from the battery. This will power up the circuits so the switches will funcion. This will get the windows up.
BENZDOC is offline   Reply With Quote
Old 11-02-2003, 11:15 PM   #3 (permalink)
kourosh's Avatar
Vehicle: 500SEL , S600L
same happend to my car i had to take it to westpoint star so they gave me a switch wh...
i had to take it to westpoint star so they gave me a switch which had two clips on it so next to the battry the is a junction box contect the two clis to each terminal if u can turn the switch to the on positon u press the swich and it stats the starter motor and the u let go and the car is on
(my barrel would turn till on position but would not go to start position)
if this is the case it will work but if this is not i cant help u .
ur Kourosh
[8D]
kourosh is offline   Reply With Quote
Old 11-09-2003, 05:48 PM   #4 (permalink)
Date registered: Nov 2003
Vehicle: 380 sel
Re: It's a long process, so if you still need it , respond to this. In the meantime , power
whats the process, or will it be better to call a mecanic to do this $$$$$$$
merbenz   Reply With Quote
Old 11-09-2003, 07:40 PM   #5 (permalink)
Date registered: Apr 2003
Vehicle: 95 E320
mine had to be replaced
i didnt do it my self but it comprised of finding a whole new key barrel with the keys, and putting that in, how, i dont know, but my alarm doesnt work any more, and i now have 2 keys, one to unlock the car and another for ignition. my mechanic did it for around 500$ i think, im not sure though it was a long time ago/ 5-6 years...
95' E 320-current ride
94' E500(Gone)
88' 300SEL(Gone)
SethMac86 is offline   Reply With Quote
Old 11-09-2003, 11:01 PM   #6 (permalink)
Date registered: Feb 2003
Vehicle: 87 420SEL
I ordered a new lock and key for the ignition from the dealer $ 110.oo it was the same k...
I ordered a new lock and key for the ignition from the dealer $ 110.oo it was the same key for the trunk. the dealer didnot want to install it for me. they said the car was to old (an 87) and it was not thier policy to work on older cars that had not serviced before.[:(!] what a bunch of crap. really the job was a pain in the back side. and I had a hard time finding someone here to do it. It finally cost me 1100.00 for the install. alot of the front trim and dash assembly had to be remove to get at it.
paul6469 is offline   Reply With Quote
