Old 10-29-2003, 12:26 PM   #1 (permalink)
560SECinCALI's Avatar
Date registered: Oct 2003
Vehicle: '88 560SEC
steering wheel replacement
We all know how huge the steering wheel is on the 560..has anybody found a reasonable replacement. Not to small and looks natural?
The Original
"Tominator"
560SECinCALI is offline   Reply With Quote
Old 10-29-2003, 02:10 PM   #2 (permalink)
Vehicle: '84 500SEC
The AMG steering wheel would be a good trade...if you can find one....
'84 500SEC Anthracite Gray
MacDubois is offline   Reply With Quote
Old 10-29-2003, 09:40 PM   #3 (permalink)
SheepAlert's Avatar
Date registered: Dec 2002
Vehicle: 560SEC
Pick up a 380MM Momo....
1989 560SEC
1987 560SEC
SheepAlert is offline   Reply With Quote
Old 10-30-2003, 05:48 AM   #4 (permalink)
Roadhouse_wannabe's Avatar
Date registered: Aug 2003
Vehicle: 500SEC
hey
I have a Momo in mine, not sure which # it is but a few people have been very surprised when I told them the steering wheel was not factory. It looks very good and looks like it could come from the factory. Plus its much smaller and its comfy!
1984 Mercedes 500 SEC Euro Spec - Vrooom
Roadhouse_wannabe is offline   Reply With Quote
Old 10-30-2003, 08:32 AM   #5 (permalink)
Vehicle: '88 560SEC
Re: hey
Sounds great. Can I keep the air bag with the MOMO? Also, is the install a diy?
Old 10-30-2003, 08:42 PM   #6 (permalink)
Date registered: Sep 2003
Sterring Wheel
You'll need a steering wheel puller. You can usually rent one for a day or get a loaner from Autozone. With a Momo, I believe your airbag will be history and be sure to disconnect the battery before you start.
I've replaced a few steering wheels in various cars over the years. With the right tools, it's a DIY kind of job.
Ed
Chicago 420SEL is offline   Reply With Quote
Old 10-30-2003, 09:23 PM   #7 (permalink)
Vehicle: 00 S500,99 4wgn,87TD
NO MERCEDES REQUIRES A PULLER. A PULLER IS FOR A TAPER SPLINE- MERCEDES HAS A STRAIGHT S...
NO MERCEDES REQUIRES A PULLER. A PULLER IS FOR A TAPER SPLINE- MERCEDES HAS A STRAIGHT SPLINE. REMOVE THE BOLT WITH A 10mm ALLEN KEY AND PULL. DONE........
BENZDOC is offline   Reply With Quote
Old 10-31-2003, 10:09 AM   #8 (permalink)
I DID NOT REALIZE THAT...DONE
