Old 10-15-2003, 04:55 PM   #1 (permalink)
Date registered: Jul 2003
Vehicle: 89 420 SEL (sold), 01ML320
Starter
Help...my starter bit the ghost. My problem is how to get at it. The bottom bolt is no problem, but the top, that's a totally different ball game!...How the hell do you get it out? Any tricks? It's on a 420 sel...I guess all the V8 are similar.
Big D is offline   Reply With Quote
Old 10-19-2003, 04:30 PM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
Re: Starter
As I recall, you need a universal joint on your socket and a long extention bar.
Once you crack it's seal, it should be quite easy.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 10-19-2003, 09:56 PM   #3 (permalink)
Got it done. I took the exhaust manifold to cat nuts off. I guess I should have waited. ...
Got it done. I took the exhaust manifold to cat nuts off. I guess I should have waited. But anyway it's all done, and working superbly. I can't believe that other than yourself, no one has changed the starter.
Old 10-20-2003, 01:19 AM   #4 (permalink)
shrimpton's Avatar
Vehicle: '90 560SEL '80 230CE
Scrolling thru' the posts,.. (as we do),.. and SUDDENLY..
... I see "cat nuts off"..
Hope this is a business that specialises in bastard bolts and not cat castrations?!..[:O]
Great to hear your problem is fixed.
Best regards,
Dennis S
<a href="http://www.wunderground.com/global/stations/93780.html?bannertypeclick=miniDial">
<img src="http://banners.wunderground.com/weathersticker/miniDial_both/language/www/global/stations/93780.gif" border=0
alt="Click for Christchurch, New Zealand Forecast" height=50 width=150></a>
shrimpton is offline   Reply With Quote
