Old 08-14-2003, 08:32 AM   #1 (permalink)
Date registered: Jul 2003
Vehicle: 420SEL
Grinding sound when going slow
My '85 280SE has begun to make a grinding sound when I'm going really slow (up to 5 mph). It sounds like brakes would sound if the pad was completely gone and it was pure metal-on-metal... but it can't be the brakes because it happens whether I'm slowing down or speeding up.
Any ideas what could be causing this noise? Is it a wheel bearing or something?
--==Aerosly==--
aerosly is offline   Reply With Quote
Old 08-14-2003, 03:01 PM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
Grinding noise
Possibly a piece of debris that has got into one of the brake calipers.
Jack each wheel up one at a time and spind it by hand to identify which one.
Then remove the pads and clean the caliper out.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
