Old 08-14-2003, 07:49 AM   #1 (permalink)
amgbnz's Avatar
Date registered: Nov 2002
Vehicle: Widebody SEC
choice performance mods
what are some of the performance mods you have done to your car?
list anything that has improved performance or mileage. this will give others ideas.
i have:
K&N filter
bosche 4+ platinum plugs
Mobile 1 synthetic oil
eibach springs
koni adjustable shocks
brullen exhaust
i'm looking for performance plug wires. any suggestions?
500SEC AMG Widebody
ML320
SLK230
1974 280 Coupe
those who want the best car in the world, drive a Mercedes-Benz
those who want the best Mercedes-Benz, drive a w126
MBCA executive board member
Mercedes-Benz Club of Canada - active member
MBFanatics.org moderator
amgbnz is offline   Reply With Quote
Old 08-14-2003, 10:57 AM   #2 (permalink)
Date registered: Feb 2003
Vehicle: 560 SEC
I have tried everywhere
I have tried AMG, Brabus, various Mercedes tuners but apart from a 5.8 or 6.0 conversion for £10,000 (Yes Thar is about $15,000), or a super charger for the same amount there is nothing around. I was told that an ECU upgrade may damage the engine given its age but I even said I will sign a disclaimer and was still unlucky. I think you just have to be lucky and but the right car. Having said that, My car goes really well with an exhaust with no side silencers and twin 4 inch pipes, I saw off a Subaru Imprezza this morning, (in a straight line). I am now after a thicker roll bar to compliment the lowered suspension and 18inch wheels, (136/35 on 8inch wide and 165/30 on 10 inch wide). I have put out a general question on this subject to this forum and if anyone has tuning gear it will be in the states, no luck.
Goos luck to you and if you find anything let me know please. Regards, Chris.
chriss is offline   Reply With Quote
Old 08-14-2003, 11:38 AM   #3 (permalink)
Vehicle: 83 500SEL
some exhaust work
I think regular copper Bosch plugs work as well or better than platinum... The platinums may have a longer life but I never consider replacing plugs to be much of a hassle or expense so I like the larger electrodes of the regular ones.
I've had my pre-cats hollowed out, side silencers removed and fitted with straight tube-shaped mufflers. I think it gets better cruising performance but a little more sluggish off the line (I think backpressure helps off-the-line perf).
Dropped a bottle of Water Wetter in the cooling system as a preventative maintenance thing...
if you're not running an aftermarket coil/ignition system, I'd say stock wires are more than adequate.
I also installed a K&N drop-in filter. No change in performance - just more economical in the long run.
oil: I stick with Castrol GTX 20W-50.
graymarket500SEL is offline   Reply With Quote
Old 08-14-2003, 01:16 PM   #4 (permalink)
1badmbz's Avatar
Vehicle: ml320, 380sec
Re: some exhaust work
I installed Dr.Jacobs Omni magnum ignition and wires,
1st gear start module from Bergwerks, Remus exhaust, and Dual intake/K&N Filter. Waiting for Foam airfilter form FXTeknology.
The best investment was ignition, complete fuel burn, and higher gas millage, and more power.
I think PerfProducts still sells these units.
Hope this helps.
Life is TOO short to drink Bad Wine.
1badmbz is offline   Reply With Quote
Old 08-15-2003, 10:55 AM   #5 (permalink)
matteus's Avatar
Date registered: Jan 2003
Vehicle: Mercedes-Benz
we once had a 560 sec (euro vers. ofcourse, in belgium[:D]), AMG 6.1 V8, 416 horsepower,...
we once had a 560 sec (euro vers. ofcourse, in belgium[:D]), AMG 6.1 V8, 416 horsepower, very nice red metalic, Black leather AMG interior, AMG body kit all around, 18" AMG Rims...
went like hell!
But ofcourse my dad had to sell it in his bussiness.
very seldom to find, but if you can find one...
boy you are lucky.
well,
cya
matteus
1991 MB 300TD: daily driver, going strong at 474.000kms
1991 MB 190E 1.8
1983 MB 190E 2.0 AMG 145PS: Restauration project up next...
2001 Alfa Romeo 147 2.0 16V Selespeed
matteus is offline   Reply With Quote
Old 08-15-2003, 07:54 PM   #6 (permalink)
amgbnz's Avatar
copper is better than platinum
you're right, copper is better than platinum for performance. platinum has a electrical conductivity rating of 14.43, whereas copper is 97.61. silver is the best material at a rating of 100 but because of oxidization there are very few silver plugs available. platinum has the advantage of less wear, therefore it maintains the proper gap longer. i chose the +4 because of the 4 electrodes.
