Old 08-08-2003, 02:42 PM   #1 (permalink)
Date registered: Sep 2002
Spring and Shock Installation
How much should I pay for spring and shock installation. Also are KYB shocks and upgrade over original 20yr old MB shocks? Thanks
PrinceGeorges is offline   Reply With Quote
Old 08-08-2003, 07:36 PM   #2 (permalink)
Date registered: Apr 2003
Re: Spring and Shock Installation
Get Bilstiens, they are much better shocks---check R &D enterprises in San Diego, CA---best price I have found---
the front shocks are cake---you can do it yourself--dont need to touch the springs
the rear, if you have self--leveling are very expensive to replace---these you need to support the rear as they do bear a fair amount of the weight
Replacing these with SW (non-self-leveling shocks) in cake
Spring replacement for me was about $250 labor---if you replace these with lowering springs make sure you get the ones W/O self leveling---my prefrence is H&R--tried the Eibachs--but the front of the car was too high--again RD Enerprises now www.shox.com -- http://www.shox.com/index.php4 has an awseome deal on these as does tire rack
trackho is offline   Reply With Quote
Old 08-09-2003, 02:24 AM   #3 (permalink)
Twizted's Avatar
Date registered: Jun 2003
Vehicle: '83 300 SD (turbo)
I've got Eibach springs on mine. The front isn't hight at all. I replaced my stock s...
I replaced my stock springs with the Pro Series Eibach and left the KYBs that were on there alone.
I did go to the "one tooth" spring shim. It's an 8mm shim versus the "two tooth" that I had on there - 13mm shim.
Have a look at my pics to see how low it is:
http://www.twizted.net/TDN-4.9/modules.php?set_albumName=Twizted_Benz&op=modload& name=gallery&file=index&include=view_album.php
<b>'84 300SD w/MANUAL TRANSMISSION</b>
<small>
Propane Injected
Air Intake tube w/cone filter
</small>
<b>'83 300 SD (propane injected)</b>
<small>
Matrix Intake
Modified Resonators
Modified Wastegate
Eibach Lowering Springs
Smoked Rear Lenses
Euro Headlights
JVC DVD/MP3/WMA deck
1 12" JL W7
Reverse Glow Gauges
Lorinser deep dish 16x8 chrome wheels
+ more...
</small>
<b>- <a href="http://www.twizted.net/" target="_blank">PHOTOS HERE</a></b>
Twizted is offline   Reply With Quote
Old 08-10-2003, 10:16 AM   #4 (permalink)
How difficult is it to replace the springs? Thanks ...
Old 08-12-2003, 11:28 AM   #5 (permalink)
Twizted's Avatar
Some people think they're easy, but they are harder to replace that springs on other veh...
Some people think they're easy, but they are harder to replace that springs on other vehicles...
