Old 05-23-2003, 05:52 PM   #1 (permalink)
cockatoo's Avatar
Date registered: Apr 2003
Vehicle: 1981 380 SEL
Vacuum timing advance problem on an '81 380SEL
Hi
I just purchased an '81 380SEL (only 167,000 km) but it is missing the vacuum line for the ignition timing.
Can anyone help me with the colour codes of the vacuum lines to the distributor and, if possible, where the advance vacuum lead comes from (the whole lead seems to be missing but it may be just tucked out of sight).
Thanks
cockatoo is offline   Reply With Quote
Old 05-25-2003, 09:38 PM   #2 (permalink)
Date registered: May 2003
Vehicle: 380sel 81
you probably don,t need it now
i have a 81 sel calif. maybe a dig. shot of the distibuter would work, but remember ca is another country when vacuum is concered.
if vacuum plays any part of smog stuff.
the color of my 380sel is steel blue?
davidlaska is offline   Reply With Quote
Old 05-28-2003, 05:46 AM   #3 (permalink)
cockatoo's Avatar
A digital photo of the distributor would be great. Any info would be appreciated (partic...
A digital photo of the distributor would be great. Any info would be appreciated (particularly the color of the vacuum leads into the distributor).
Old 05-29-2003, 11:55 AM   #4 (permalink)
Vehicle: 380sel 81
the vacum lines attach under the dist. and are dual colored which i could not make a usefu...
the vacum lines attach under the dist. and are dual colored which i could not make a usefull picture. If you draw a picture with lables a b c etc. I could rely by writing a = green/ blue etc. Naturly if you have a easier way to achieve this, that s fine to. If I am not clear, let me know if you still need it, I will reply
Old 06-04-2003, 05:38 AM   #5 (permalink)
cockatoo's Avatar
I only have one vacuum lead going into the ignition timing module and that is yellow with ...
I only have one vacuum lead going into the ignition timing module and that is yellow with an orange tracer. That one is on the left of this unit looking at it from the front of the car.
On the right hand side, but a little higher, there is the timing advance input - currently just a soft black hook-shaped rubberised lead which is there for a stiff plastic vacumm - probably coming from one of the two vacuum switches on the left-hand side of the engine bay.
There are a number of those plastic vacuum leads running from the switches and passing underneath the timing adjustment unit and I presume that the missing vacuum lead is part of that collection of vacuum leads.
I appreciate your assistance with this as the car is using bulk fuel as the timing advance is not working. I purchased a double CD set which is supposed to have the workshop manuals in them. They arrived today. Unfortunately, only one worked, and that didn't include the vacuum info. Aaaarrrggghhh!!!!! [:(]
Old 06-05-2003, 08:21 AM   #6 (permalink)
Vehicle: 380sel 81
clean
I went ahead and had the engins cleaned since it would be better to work on. I checked all my vacums and there is one nipple that seems to be missing one . I will study your info and seel is i can get back something sensible for you
Old 06-05-2003, 06:03 PM   #7 (permalink)
cockatoo's Avatar
Any info you (or anyone else) can offer would be greatly appreciated. ...
Old 03-05-2007, 10:58 AM   #8 (permalink)
Date registered: Dec 2006
Vehicle: 1991 420 SEL
I just got done working on my timing chain and, in the process, I snapped the vacuum tube (appears clear, no orange stripe) going to the ignition module (227 400 693). The engine is idling very rough now.
Firstly, could this be a cause of the rough idle? Secondly, where does this vacuum tube go from the ignition module?
I'm working on a '91 420 sel.
surfjones is offline   Reply With Quote
Old 03-05-2007, 12:37 PM   #9 (permalink)
Date registered: Jun 2006
I was just looking through the factory shop manual and in 1981 some of the models do not have a vac hose going to the distributor, they only have the black curved hose facing down probably so water won't get in and says it is to vent to atmosphere.
Dave D is offline   Reply With Quote
Old 03-05-2007, 05:56 PM   #10 (permalink)
500MPL's Avatar
Date registered: Jan 2004
Vehicle: 1984 500 SEL euro, 1989 560 SEL, 1980 450 SL, 1981 DeLorean
Hope this diagram will help.
Regards,
500MPL is offline   Reply With Quote
