Old 04-20-2003, 10:13 AM   #1 (permalink)
Date registered: Sep 2002
shift knob removal
Has anyone removed their shift knob before? I have no idea where to start, so any help would be appreciated. Thank you
PrinceGeorges is offline   Reply With Quote
Old 04-25-2003, 12:37 AM   #2 (permalink)
Vehicle: 89 560SEL
The shift knob is permanently attached to the shift lever. The lever comes out from the ba...
The shift knob is permanently attached to the shift lever. The lever comes out from the base. Pull the centre console wood trim out and work down to the base of the shifter and you should be able to work it out.
Matt.
89 Euro 560SEL
Clear front side and rear lenses
17in AMG Monoblock II's
H&R springs
Kmac camber kit
1st gear start
http://homepages.ihug.co.nz/~mattpetersen
mattman is offline   Reply With Quote
Old 04-30-2003, 08:05 AM   #3 (permalink)
Thanks I was able to switch my knobs last night. I put the spring on backwards so the kno...
Thanks I was able to switch my knobs last night. I put the spring on backwards so the knob doesn't snap back into the slots but it looks nice.
