» Site Navigation » Other Sites
» Network Links
04-13-2003, 06:48 PM
#1 (permalink )
Normal operating temperature for '84 300SD Turbo Diesel
1984 300SD Turbo Diesel owners or similar
What is the normal operating temperature you are seeing?
I'm seeing 100 Celsius on freeway driving.
04-14-2003, 09:23 AM
#2 (permalink )
Date registered: Mar 2003
Vehicle: 1988 560 SEC
That is a little hot for an SD. Your thermostat is probably stuck open. Easy fix that happ...
That is a little hot for an SD. Your thermostat is probably stuck open. Easy fix that happens all the time on those cars.
04-14-2003, 09:39 AM
#3 (permalink )
It should be running at about 90 degrees, running at 100 is not hurting it, if you are won...
It should be running at about 90 degrees, running at 100 is not hurting it, if you are wondering, but all three of my fathers 300SD's run just over the 80 mark on the gauge.
02-17-2005, 07:15 PM
#4 (permalink )
Date registered: Jan 2005
RE: That is a little hot for an SD. Your thermostat is probably stuck open. Easy fix that happ...
you should running at 80 degrees. over 75 mph for a prolong period it may move up one or two degrees. mine went over 85 and i lost a big end,and an engine block.
hugh
02-17-2005, 08:28 PM
#5 (permalink )
Date registered: Nov 2003
Vehicle: 1985 300sd
RE: Normal operating temperature for '84 300SD Turbo Diesel
80 degrees celcius is the correct temperature for the car to be running at.
Thread Tools Display Modes Linear Mode
