Old 02-25-2003, 01:09 PM   #1 (permalink)
Date registered: Dec 2002
Vehicle: 1991 420 SEL
Problem starting the engine
[:)]Hi
My 91 420sel developed an odd habbit in the past 2-3 weeks. It used to start almost immediately in the morning, but now after I turn the key it would turn the engine, but wouldn't start it. If I turn the ignition off and turn it back on, the car would start immediatly.
What I did lately I've added a few bottles of injector cleaner and gas treatment.
Any suggestions would be appreciated
MECTHET is offline   Reply With Quote
Old 02-25-2003, 02:18 PM   #2 (permalink)
Vehicle: 83 500SEL
how old are your ignition components?
spark plugs, spark plug wires, ignition coil, cap and rotor?
graymarket500SEL is offline   Reply With Quote
Old 02-25-2003, 03:01 PM   #3 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
Bad Starting
MECTHET
Every time you turn the igintion on, it primes the fuel pump and it sounds as if your fuel pressure is dropping when the car is stood.
To test this theory, when you come to start the car tomorrow, turn the ignition on but do not start the engine. Let the igintion stay on for about 2/3 seconds then turn it off and on again.
Let the ignition stay on for another 2/3 seconds before kicking in the starter motor.
If it starts, it is a fuel pressure problem.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 02-27-2003, 08:21 AM   #4 (permalink)
Trouble starting the engine
Thanks for the info. I just changed my plugs, but didn't touch the wires or the rotor.
[8D]
Old 02-27-2003, 09:05 PM   #5 (permalink)
Smells like fuel!
Sounds like you have either a 1)bad primary fuel pump check valve, or 2)leaky fuel nozzle.
The system must maintain >40PSI in the system pressure side. If the check valve (in pump outlet CLOSEST to fuel tank) leaks, pressure falls and the car has extended cranking. On some occasions the damper assembly above the fuel pumps perforates. MB said that cranking up to 4 sec was normal but this is BULLSHIT. It should fire INSTANTLY upon cranking if things are ok. Mine with 226K does.
This is an ASE Master Certified MB mechanic- hope it helps.
rpgrace75 is offline   Reply With Quote
