Old 02-09-2003, 02:06 AM   #1 (permalink)
Vehicle: 300 se
Strange Brake noise
Hi all !! 300se 206550km
Was driving with my window open this morning and noticed a clunck noise eminating from right (right hand drive) wheel every time i brake. the noise can be quite loud at times but only occurs when i brake !
ALSO!!!
weird clonking noise eminating what seems to me like from somewhere in the steering column cause it only occurs when i drive on rough surfaces any ideas bushings ? steering box tie rods mmm ..had new shocks fitted etc..
ANY ADVISE WHAT TO LOOK FOR ?????????????????????
leon
L. Nel
leon is offline   Reply With Quote
Old 02-09-2003, 09:39 AM   #2 (permalink)
Thguns's Avatar
Date registered: Jan 2003
Vehicle: 560 SEL, SEC Koenig
Clunking noise
In order of likelihood, (but if you're high mileage, change them all. The
parts are cheap.)
Guide rod mount. You'll need 2 @ $41
front subframe mounts, 2 rubber mounts in each of 2 free-floating subframes
that hold the guide rod mount. About $14 each. Pix is roughly representative
of all 4 bushings. So under $150 parts cost, with shipping.
This is the path of almost all force when braking and much of the turning
force. They can be changed by a DIY'er, and should be, otherwise the parts
cost is NOTHING compared to the labor cost. You must get an alignment
afterwards, and you better have scrap or spare tires to drive to the dealer
to get the alignment after changing these bushings, the tires could be
scooting sideways. NO KIDDING, it'll ruin your good tires really quickly.
Thguns is offline   Reply With Quote
Old 02-09-2003, 09:46 AM   #3 (permalink)
Thguns's Avatar
more front suspension
Prices in US dollars
Old 02-14-2003, 01:02 AM   #4 (permalink)
driveright's Avatar
Date registered: Feb 2003
Vehicle: 1990 300SE
Front End Noise
I have the same situation on my 300SE. I have been assured that the noise is, as stated previously, eminating from the stering rods and that it is not a problem, unless the noise has become too irritating. I haven't had the time to deal with it, so I have let it be. So far I can still steer.
driveright is offline   Reply With Quote
