Old 11-29-2002, 11:00 PM   #1 (permalink)
amgbnz's Avatar
Date registered: Nov 2002
Vehicle: Widebody SEC
looking for cross-drilled front rotors
i am looking for front cross drilled rotors for a 1984 500SEC. anyone know where i can find some. stock diameter.
any location.
500SEC AMG Widebody
ML320
SLK230
1974 280 Coupe
those who want the best car in the world, drive a Mercedes-Benz
those who want the best Mercedes-Benz, drive a w126
MBCA executive board member
Mercedes-Benz Club of Canada - active member
MBFanatics.org moderator
amgbnz is offline   Reply With Quote
Old 11-30-2002, 09:05 PM   #2 (permalink)
Date registered: Sep 2002
Vehicle: 420 SEL (1989), 190 E (1990)
Check out performanceproducts.com ask them if they have it by calling them. You can get th...
Check out performanceproducts.com ask them if they have it by calling them. You can get their tel # from their website. If you don;t find it there then go to the Brembo site, and contact them to see if you can can find it with them.
Hope this helps
Sohaib
Education is what is left when what was learnt has been lost!
xsohaib is offline   Reply With Quote
Old 12-02-2002, 12:01 AM   #3 (permalink)
Date registered: Dec 2002
rotors
Try ATE Power Discs. They have eliptical grooves and work well to dispell any gas build-up. Down side is the over pressure on the front thrush bushings. I'm on my third set in 50k mi. I can do a front wheel stand, however.
arby is offline   Reply With Quote
Old 12-02-2002, 12:17 AM   #4 (permalink)
NO FREAKING WAY! If you can do that you HAVE to put up a pic!!...
sebastian is offline   Reply With Quote
Old 12-02-2002, 08:23 AM   #5 (permalink)
Vehicle: 500SEL AMG
disks
performancemotorcars.com or **********.com has the zimmerman x-drilled rotors for sale.
Hans
mbcouple is offline   Reply With Quote
Old 12-02-2002, 08:46 PM   #6 (permalink)
amgbnz's Avatar
zimmerman's look good
thanks hans
so far the zimmerman cross drilled from performancemotorcars.com or **********.com look good but neither will ship outside the US. i'll keep trying another source.
Old 12-04-2002, 12:39 AM   #7 (permalink)
shrimpton's Avatar
Vehicle: '90 560SEL '80 230CE
PESTER THE HELL OUT OF PERFORMANCE amgbnz!!!!
They seem to be right royally up themselves from long distance communications I've had, and in relative terms of distance - you're in spitting range!. I am persisting with them because A) they have stuff I want, and B) I can't find this stuff elsewhere.[:(!] Think you have problems from Canada? - I might as well be on Mars down here in New Zealand!
Please persist, for the more we can break down their "for USA only" bullshit, the sooner they may remember that USA DON'T MAKE MERCEDES - nor anything near as good, and have to import themselves!!
Emails from Performance seem to take a week to get a response - maybe they're busy......[8D]
<a href="http://www.wunderground.com/global/stations/93780.html?bannertypeclick=miniDial">
<img src="http://banners.wunderground.com/weathersticker/miniDial_both/language/www/global/stations/93780.gif" border=0
alt="Click for Christchurch, New Zealand Forecast" height=50 width=150></a>
shrimpton is offline   Reply With Quote
