Old 10-03-2002, 02:23 AM   #1 (permalink)
560sec's Avatar
Date registered: Sep 2002
Vehicle: 560 SEC/SEL
leaking Trans. question affecting engine
I have a prob, my car will smoke and start to miss only when idel in a decline position or when i slow down to a stop on a decline quick. i was told this is a leaking trans seal. i was wondering if anyone knew what could be the seal that is leaking.
Thanks
<IMG SRC="http://www.mbnz.org/gallery/goto.asp?id=16459"/>
560sec is offline   Reply With Quote
Old 10-03-2002, 01:45 PM   #2 (permalink)
spw1's Avatar
Smoking Car
I have a similar problem, was told that it probably was the Transmission Modulator, had it replaced and it still does it - I am thinking Valve Guide Seals now
spw1 is offline   Reply With Quote
Old 10-04-2002, 12:30 PM   #3 (permalink)
560sec's Avatar
smoking
i was also told it was the trans modulater but i replaced and still happens, also was told it was the valve guide seals but what is strange is that it doesnt happen all the time, i am so used to the way it smokes that i can make it smoke or not, i am thinking about this leaking trans seal? but i am not sure what would allow fluid to pass and enter the engine? i am still doing research on this one
Old 10-04-2002, 04:06 PM   #4 (permalink)
spw1's Avatar
Let me know what you find out
What exactly are the symptoms that you see? Mine is strange too, because I CANNOT make it happen at will.
Sometimes it does it alot, sometimes it doesn't. Mine seems to do it more when there is more oil in the pan - e.g. like just after an oil change
Also seems like it happens when decelerating hard down a hill, then accelerating - but again not always
Mine gives a big-time cloud of smoke...
