I had took my 300sd up to 125mph, does anyone know what the top speed is??
The 1977-1980 model was rated at 103 mph tops. The 1987 model was rated at 119 mph for the 300 SDL, 103 for the 300 SD. You have certainly broken the record according to the factory specifications.
[:D]
I've had mine up to 71 MPH, i'm not sure what kilo's that would be, but my RPM at 71 MPH was around 3300, so I didn't push it any more. Please write back on your RPM's because I'd like to know if my RPM's are normal to be that high at 71 mph, and at 125 mph I bet your RPM's were pretty severe!
j
The fastest I've gone in my 300SD is about 150km/h, which is about 94mph. I never pushed it anymore because I just got my licence and she's my first car, but the previous owner top at 165km/h, about 105mph. Also, the front wheels needs to be balanced, so at 95mph, the steering whobbles a bit to much for me and the tires aren't the best out there, plus she's old, but still running [:)]
1990 Mazda MPV
1988 Mercedes-Benz 560SEL 260k KM
1981 Mercedes-Benz 300SD 255k KM (died 11/11/2002)
Like cars? Check out my site
http://twitch.zonehere.com
And you're watching http://www.PCMTL.com Ep #21,22: TeamSCP Jarry Parc
is there a difference in the top speeds of 1981 300sds and like 1983 ones, because my sp...
is there a difference in the top speeds of 1981 300sds and like 1983 ones, because my speedometer goes up to 85 mph while i have seen some 300sd speedometers that go way beyond 85 mph. The fastest i have driven is 85 mph (probably a bit faster because the rpms were still increasing but the speedometer needle was as far as it would go so im guessing i have gone maybe 90 mph)
The speedo of my 1981 300SD goes up to 200km/h, 125mph. The funny thing is that my speedo is only in metric (km/h), and Canada changed to metic system in 1980 I think. Cars after 1980 have both metic and English sytem, but mine only has metric. Does it mean it was imported from Europe?
Well, after the peek torque and hp at a certain rpm, the graph of torque and hp drops, so you don't get any more power, so I think since you're producing less and less power, your speed drops.
