Old 10-01-2002, 05:07 PM   #1 (permalink)
JLTbenz's Avatar
Date registered: Sep 2002
Vehicle: 1984 300SD
Battery Problem
After having my 1984 300sd turbo diesel for 4 years i realize that i have problems with my battery. My car for some reason dies very frequently. Does anyone else have this problem as well??? Should i replace the battery?
JLTbenz is offline   Reply With Quote
Old 10-01-2002, 09:38 PM   #2 (permalink)
Vehicle: 420 SEL (1989), 190 E (1990)
Perhaps it is the alternator. Sohaib...
Sohaib
Education is what is left when what was learnt has been lost!
xsohaib is offline   Reply With Quote
Old 10-01-2002, 10:30 PM   #3 (permalink)
JLTbenz's Avatar
Vehicle: 1984 300SD
Alternator
How much do alternators go for? Also is it easy to change it?
Old 10-02-2002, 08:06 AM   #4 (permalink)
Vehicle: 90 300 SE ,85 300 GD
Re: Alternator
Check the price at Gapa.com. They will give you an idea of what's available.
Ed Mclass is offline   Reply With Quote
Old 10-02-2002, 01:26 PM   #5 (permalink)
RSH
Vehicle: 1983 Mercedes 300SD
battery problem
I do not think the battery has anything to do with the engine running or in your case stalling, other than to start it and to help the alternator. You can check the battery static voltage (non running) it should read about 12.6 vdc then check it when running it should read about 13.4 to 14.0 vdc, you can use a multimeter.
RSH is offline   Reply With Quote
