i got an 82, 500sel last year,what is the # 3,2 & B on the gear shift for.also can i get a manual for the car online,i cant get any from the dealers in Nigeria.
the 3rd. gear is for the car to run in 3rd. gear when driving, and on a kick down, you'll get it down to 2nd.
the 2nd. gear's to lock the car into 2nd. gear only, this is excelent for pasing other cars.
the B gear is your first gear. when switching over to the B gear, you'll get excelent take off acceleration. it's also used for braking and climping steeps.
1st. question:yes, you may start driving from B. when your aproching the speed limit...
1st. question:
yes, you may start driving from B. when your aproching the speed limit for 1st. gear, just pull the lever into 2. it'll then gear correctly into 2nd. gear, and so on for 3rd & 4th.
2nd. question:
yes, you may use the gears for decelerating. the 3 & 2nd. gear are quite usefull for this, but be carefull switching it over to the 1st. gear. one thing is that it's not all healthy for you auto.box when done often. another thing might be your speed when decelerating, it's often to high for the 1st. gear. but this you probably know, check out the markings on your ODO...
engle,
my criuse control is in german,i dont have a manual,how do you use the criuse control? your looks great & i am sure it drives great,how long have you had it?
i've had it since june 2000...
it doesn't look the same now, I've been restoring it.
well, mine too. My 500 sec is an early euro model without the criuse control. but my us 420sel had one, don't quite remember but it wasnt hard to fint out.
you can't mess anything up, so just fiddle around with it for i while... there's probably someone else on the forum that can help you out more then i can.
