Considering purchasing a SEC - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 06-17-2017, 10:31 PM Thread Starter
liammarsh's Avatar
Date registered: Apr 2009
Vehicle: 1981 300 SD, 1994 C280, 1990 560 SEC
Quoted: 2 Post(s)
Hello Good People, I've been away for some time though have been using my SD still as my daily driver. I went through years of turmoil related to trying to get a staggered set, 8/9, of Penta rims (Penta brand made in Britian). Short version is I was never able to get them to fit on my SD which is lowered with Eibachs. I drove around with them for a long time though discovered that they were getting destroyed on the inside of the rear passenger side. Anyway that and my 15 daughter backing into it as she learned to use a stick shift left me disheartened on the car. I got a 94 C280 for $400 to fix and flip but ended up really liking how it drove and was about to buy a cleaner version of one when I happened upon a 90 SEC black/black.
Just when I thought I was out, they pulled me back in!
So this car is completely stock, pretty clean inside and out, 168K and is reported to have only a couple problems (needs fuel pump relay and central locking pump). Owner is second one and he is checking with the original owner's mechanic, who he knows, to see if the timing chain has been done. Priced at $2500 so I am thinking a pretty good deal? Saw it tonight and I am going to test drive it on Monday.
So my questions:
Anything about the deal I should worry about assuming the car races well and shifts smoothly?
Can I get my 8/9 rims on there and have them fit without having to bend anything? They are ET 11. I won't be lowering it. I'll get some pictures of my rims on my SD tomorrow and post.
Thanks for the help and good to be back!
liammarsh is offline
post #2 of 15 (permalink) Old 06-18-2017, 04:47 PM
KRH
KRH's Avatar
Date registered: Nov 2009
Vehicle: 87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Quoted: 382 Post(s)
Yes the British Penta front 16 x 8 et11 and rear 16 x 9" et11 are a straight bolt up
(how do i know because i also have a set of those plus the AMG/ATS version 8/9 combo)
Best tire set up is from tirerack rear BFG 255/50/16 rear
Front for non lowered is 225/55/16
There are no inner tire clearance issues at all and no outer as well
If front is lowered then you go down to 225/50/16 tire but if not lowered it leaves too much gap to the wheel arch and looks odd.
<a href=https://flic.kr/p/TFzygw target=_blank><img src=https://c1.staticflickr.com/3/2875/33922085756_33ce87aec9_m.jpg border=0 alt= /></a><a href=https://flic.kr/p/TFzygw target=_blank>Avatar</a> by <a href=https://www.flickr.com/photos/krh2013/ target=_blank>Kim</a>, on Flickr
87 White Euro 500 "ECE" 265hp SEC
88 Black Euro 560 "RUF"300hp SEC
89 Blue Euro 560 "RUF" 300hp Hydro SEL
https://www.flickr.com/photos/krh201...57668572599252
http://www.flickr.com/photos/krh2013...7632548663623/
KRH is offline
post #3 of 15 (permalink) Old 06-18-2017, 07:11 PM Thread Starter
liammarsh's Avatar
Quoted: 2 Post(s)
Thank you KRH, just the info I needed! I think I will buy the SEC so that I have a reason to keep the Pentas! Have 245/45 and 225/50 on there now but they need replacing. Drove around on them on the SD for a couple of years but there were rubbing issues and I didn't realize how bad the inside problem was. Lucky I didn't have a blow out. (Tried to add pix but they were always upside down???)
ID:	2194234   Click image for larger version
Name:	tore up tire.jpg
post #4 of 15 (permalink) Old 06-19-2017, 07:53 AM
Date registered: Apr 2004
Quoted: 59 Post(s)
$2500 for a nice 560SEC is a great price. Buy it as these cars are starting to float upwards in value, mark my words.
slownrusty is offline
post #5 of 15 (permalink) Old 06-19-2017, 11:57 AM
GreenT's Avatar
Date registered: Mar 2013
Vehicle: 1995 S500, 1990 420SEL
Quoted: 7074 Post(s)
I was getting a headache...
ID:	2194546   Click image for larger version
GreenT is offline
post #6 of 15 (permalink) Old 06-19-2017, 04:37 PM Thread Starter
liammarsh's Avatar
Quoted: 2 Post(s)
Thanks GreenT for the help with the pix!
GreenT likes this.
post #7 of 15 (permalink) Old 06-24-2017, 10:08 AM Thread Starter
liammarsh's Avatar
Quoted: 2 Post(s)
With great ambivalence I bought the SEC (90, black on black, 162K). At a distance all looked well but after test driving it I discover that the brakes fluttered greatly with the ABS light going on and off. The under carriage had a lot of oil everywhere, shocks were completely shot and the driver seat felt to have a broken spring. Paint had a few chips and the hood must have been repaint because it was faded in a completely atypical way. So it looked like not a lot of maintenance had happened. Engine was mighty though, transmission shifted smoothly and the alignment was straight. Got up to 95mph quickly so as an SD driver that was very fun. Wanted to walk away but couldn't and got him to agree to $2200. She looked pretty in my driveway when I woke up in the morning so I'll let her stay a little while.
I've lived the truth already of the great expense of a cheap Mercedes though the journey was priceless. The other thing less stated here is that in terms of marriage it is a lot easier to buy a cheap Mercedes and then launder money into it slowly over time. Have 3 Mercedes (and pickup) and need to get down to one Mercedes. Next up I am going to play around with my wheels and will post pictures. Goal is to get the Pentas on the SEC and the GenII rims on the SD. At first pass it looks like the tires on the Penta will be to short and the tires on the GenII's will be too tall but I will test them both first.
Currumbin SL likes this.
post #8 of 15 (permalink) Old 06-24-2017, 10:20 AM
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 992 Post(s)
Nice start, check your rubber fuel lines under the hood and check the chain guides unless there is documentation where they've been changed already
liammarsh likes this.
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC "Ursula"
'91 300SE (sold) "Sadie"
'98 Yota RAV4
'02 S-10 Truck
'72 SeaBird boat, "Riff Raft", overhaul restarted, will have new transom wood, new stringers and deck, plans are to upgrade to a V6 Chevy engine, virtually a brand new boat with a 45 year old hull
Dif-tor heh smusma I'm surprised that NOBODY has asked me what this is / means LOL
wooky_chew_bacca is offline
post #9 of 15 (permalink) Old 06-24-2017, 03:43 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 384 Post(s)
I looked at this $9,500 gem today for a fellow member.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers.
281lxm is offline
post #10 of 15 (permalink) Old 06-24-2017, 04:33 PM
81126's Avatar
Date registered: Dec 2007
Vehicle: 1985 300SD 1988 560SEC 822 1976 450SEL 1981 300SD
Quoted: 28 Post(s)
$950 at best..
wooky_chew_bacca likes this.
Just say no to sparkplugs[SIGPIC]
81126 is offline
