Febi tensioner vs Mercedes - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 03-19-2017, 05:48 PM Thread Starter
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL
Quoted: 25 Post(s)
I have been reading all the posts about changing the timing chains but
I have a couple of quality questions. The mercedes brands on the tensioner is about $345 and on the gears about $180 each. The Febi brand is about $80 for the tensioner and $25 for the gears. The chain I get using Mercedes but is there that much difference difference in the other parts. All of a sudden if I use Mercedes parts one is looking at $1000 for parts alone. So convince me that the difference is worth using an oem tensioner. Thanks
Stutz is offline
post #2 of 15 (permalink) Old 03-19-2017, 06:01 PM
PWogaman's Avatar
Vehicle: 80 280SL, 85 300SD, 87 300TD, 90 300TE 4Matic, 90 300D 2.5 Turbo, 92 300D 2.5 Turbo, 92 300TE 4Mat
Quoted: 31 Post(s)
500E / E500 Parts Manufacturer Quality List
wooky_chew_bacca likes this.
Current
80 280SL
85 300SD
87 300TD 2Matic
90 300TE 4Matic
90 300D 2.5 Turbo 2Matic
92 300D 2.5 Turbo 2Matic
92 300TE 4Matic
01 Saab 9-5 Wagon FrontWheelDriveMatic
Former
91 300E 4Matic; 96 Dodge Grand Caravan; 76 450SL; 77 350SLC; 87 VW Cabriolet; 87 VW Golf GL; 88 Ford Ranger; 80 VW Rabbit; 80 Dodge Ramcharger Snow Commander; 75 Simca; 67 VW Beetle; 59 Bultaco; 57 VW Beetle; Honda CX500; Kawasaki 250; Honda CB50
PWogaman is offline
post #3 of 15 (permalink) Old 03-19-2017, 08:48 PM
magicbigdaddy's Avatar
Date registered: Dec 2006
Vehicle: 1989 560 SEC - V-8 Kompressor - 95 E320 Estate
Quoted: 153 Post(s)
Or just do a search on this forum "febi chain tensioner". Won't be good news.
1989 560 SEC Supercharged - 317+ rwhp - H&R lowered - OZ Nova's - upgraded brakes - AMG Tri-Y's - Bergwerks FGS - a true Euro Rod
1995 E420
1985 500SEC
magicbigdaddy is offline
post #4 of 15 (permalink) Old 03-19-2017, 09:05 PM Thread Starter
Stutz's Avatar
Vehicle: 1999 500SL
Quoted: 25 Post(s)
Thanks, got the message. Lots of info on that brand
Stutz is offline
post #5 of 15 (permalink) Old 03-20-2017, 05:14 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1987 560SEC Now 145K mi. (Summer 2016)
Quoted: 139 Post(s)
Hi Stutz,
In addition to the above wisdom…
In my opinion, this one part is SO critical to have right, its just NOT worth it to futz around in an attempt to save possibly a couple hundred dollars….
It would be a massive and avoidable shame to have an aftermarket chain tensioner bleed down .. chain jump time … etc…. Possible subsequent damage & costs might well be staggering by comparison.
Good luck man,
MBL
MBL87560SEC is offline
post #6 of 15 (permalink) Old 03-20-2017, 10:33 AM
Date registered: Apr 2010
Vehicle: '89 560SEC, '90 560SEL
Quoted: 97 Post(s)
Yeah, avoid the Febi tensioner. Febi isn't universally junk (I have a "Febi" oil pump in my SEC that's just a re-boxed OE pump, for instance), but it's a brand that has at least as many misses as hits, quality-wise. Caveat emptor. Not sure what the failure rate is, but I've heard enough bad reports that I'd leave the original tensioner in before I'd use the Febi one.
You should be able to do the whole job for $500-600 in parts. I priced it out a couple months back, but can't remember the exact number. Most people don't replace the sprockets, and it's not necessary unless you've got really high mileage and/or they show a lot of wear. It's the tensioner and plastic guide rails that cause failures.
'89 560SEC, 234K, pearl white with palomino interior - Liesl
'90 560SEL, 192K, champagne with mushroom interior - Ingrid
'97 Ford F250, 189K, diesel, blue, 4x4, manual
'64 Ford Fairlane with approximately 240K
MT_Merc is offline
post #7 of 15 (permalink) Old 03-20-2017, 02:43 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1037 Post(s)
The chain (iwisketten, means iwis chains) are the same whether from the dealer, or at lower price from various online sellers.
However, the dealer has a nifty looking bronze master link I am partial to for only a few bucks extra.
Teutone is offline
post #8 of 15 (permalink) Old 03-20-2017, 03:58 PM Thread Starter
Stutz's Avatar
Vehicle: 1999 500SL
Quoted: 25 Post(s)
Thanks guys. I will heed your advice. One quick question on the work. The searches all talk about doing the timing chain work but do not mention whether to do valve seals when you have it almost that far apart. I also have not seen where the seals are an issue, but is this something I might want to tackle while doing this? The car has 100,000 on it. I do appreciate all the comments. I also have a R129 and without that combined Mercedes knowledge I would be lost.
Stutz is offline
post #9 of 15 (permalink) Old 03-20-2017, 09:08 PM
wooky_chew_bacca's Avatar
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 944 Post(s)
I don't know about the seals either but with the chain guides in particular the consensus is that they should be changed every 100K miles but especially with our cars now at 25+ years even the low mileage examples should have them changed. The tensioner, as was stated before, should go ahead and get a MB part instead of taking the expensive roll of the dice with aftermarket. The window and boot rubber are another to go MB with. That list that PWogaman posted, I have it saved here and refer to it when shopping for parts
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC
'91 300SE (sold)
'98 Yota RAV4
'02 S-10 Truck
'72 SeaBird boat, overhaul on hold
Dif-tor heh smusma
wooky_chew_bacca is offline
post #10 of 15 (permalink) Old 03-20-2017, 09:16 PM
GreenT's Avatar
Date registered: Mar 2013
Vehicle: 1995 S500, 1990 420SEL, 1986 420SEL sold, 1997 E420 sold
Quoted: 6619 Post(s)
Get familiar with this video.
GreenT is offline
