1991 560sec what is the PSI transmission ? I've seached and found different numbers ( 56,48,46 ) I need the correct PSI to adjust the modulator .Also is this psi at idle or at 30mph.Also need the thread size for putting in a bango bolt to set psi. Thanks to all for help.
MB has different numbers depending on the year - not sure why, not a transmission expert, but that's what I've read. My experience has been to adjust the modulator depending on the type of shifting I was looking for... slightly firmer but not too hard as to damage the tranny long term. Others prefer a smoother pattern.
Lots of good info in this manual put together by a member here.
Guys thank you for all your input . I have two ???? (1) Do I set the PSI with vacuum line off of modulator or with it on? (2)should I try and set my psi form 48 to 50 psi. again thanks.
You set the modulator pressure with the vacuum line disconnected.
-J
