Old 07-08-2002, 08:48 AM   #1 (permalink)
Date registered: Dec 1998
Trunk Lid badge
Hi everyone,<br> <br> I have just recently bought a 500SE (1984) Euro model (as I am european) and what a great car it is. The previous owner had to replace the trunk lid because of damage. He told me about this when I had questioned where is the '500SE' badge. (It is a genuine 500SE because I had thoroughly checked out the engine and vehicle data records through an independant organisation which all match). <br> <br> The previous owner advised me that the trunk lid replacement had come off a 280SE. The original pin wholes holes for the 280SE badging are still there (even though the trunk has been resprayed and blended in with rest of the paintwork. The previous owner thinks that a 500SE badge should slot straight into the pin holes (this being the reason why he didn't get the bodyshop to fill the pin holes in).<br> <br> My local dealar is not very helpful and is useless, and to order the 500SE badge replacment, I have to pay up front and cannot get a refund if the pin holes do not line up and fit. <br> <br> Does anyone know if the alignment of the pin holes are the same between a 500SE and 280SE badge before I order the 500SE badge replacement???<br> <br> Thanx guys.<br> <br> <br> <br>
Old 09-19-2002, 04:49 PM   #2 (permalink)
Date registered: Sep 2002
Vehicle: 1991 300SEL W126
The badge on my '91 W126 was decal-backed and didn't make use of pins at all. I'd suspect ...
The badge on my '91 W126 was decal-backed and didn't make use of pins at all. I'd suspect the same for your car. Did you ever find out about this for sure?
dallasrob is offline   Reply With Quote
Old 09-22-2002, 11:17 PM   #3 (permalink)
kourosh's Avatar
Vehicle: 500SEL , S600L
badge
hi
i replaced my 500se trunk lid with one from a 280se
it made no difference and it slid right in
all the defference between a SEL and a SE is that the
SEL has one more pin on the L
I hope ths info helps you
Kourosh atashnafas
[8D]
kourosh is offline   Reply With Quote
