Old 03-07-2002, 07:03 PM   #1 (permalink)
Date registered: Dec 1998
Trunk leak
I just got a new trunk seal put in so I'm pretty sure its not coming from that. What else could the problem be in a 300SD?
Old 03-07-2002, 09:05 PM   #2 (permalink)
Re: Trunk leak
Rear window seal between body and seal is actually the most common place for water to enter the trunk. Look to the lower corners of rear windscreen.
Old 03-08-2002, 03:17 AM   #3 (permalink)
Re: Trunk leak
Scroll down the page to this post:<br> <br> Boot (trunk) leak in W126 1982 280SE<br> <br> or shortcut: http://forums.mbnz.org/forums/W126/vthread.asp?messid=1519<br> <br> This is your problem.<br> Good luck!
Old 03-08-2002, 07:52 AM   #4 (permalink)
Re: Trunk leak
thanks
Old 03-10-2002, 10:25 AM   #5 (permalink)
Re: Trunk leak
I read heppsens. post exactly how much did it cost and were you abel to do it yourself or did you go to a mechaninc.
Old 03-10-2002, 01:46 PM   #6 (permalink)
Re: Trunk leak
I'm going to do it myself with the help of a friend to remove the screen. That way I know any rust will be properly fixed. A new screen seal is about $50 Australian. I could get a smash repair shop to do it but am worried that they won't stop the rust from reappearing, so have decided to do it myself.
Old 03-10-2002, 09:04 PM   #7 (permalink)
Re: Trunk leak
oh ok just let me know how it turns out and what you have to do please because I might want to try. thanks
