I've just purchased a 1991 420 SEL and the antennae doesn't come up when the radio is on. The radio manual claims there is a rocker panel above the radio that controls the antennae, but all the switches above mine seem related to the A/C fans, etc.<br>
<br>
Is there some control on the radio or elsewhere or is it possible that the antennae just isn't getting power?<br>
<br>
Any help is appreciated, thanks in advance...
Just to the right of the red flash button should be the 'ant up down ' button ..If that doesn`t work, You may have to open the trunk and pull away gently the board on the left side to gain access to the ant. motor have someone operate the radio or ant up down button , and see if the motor runs and grabs on to the white plastic leader for the antenna. You can get a new one and thread it through the motor Good luck
