Old 07-06-2000, 02:58 PM   #1 (permalink)
Date registered: Dec 1998
91 300SE A/C
the A/C will kick into the defrost mode (blows from the top vent) on any icrease of RPM. it will blow from the front vent once the engine has leveled off. is this normal with this model?
Old 07-06-2000, 06:57 PM   #2 (permalink)
Did you experience this before ?
I never experienced this happening to mine <br>although I'm not sure coz' I never noticed. <br>I'll check tomorrow on my way to work.<br>So that's any increase right ? No specific RPM.<br>I'll post again tomorrow on my findings.<p>Anton<p>: the A/C will kick into the defrost mode (blows from the top vent) on any icrease of RPM. it will blow from the front vent once the engine has leveled off. is this normal with this model?<p>
Old 07-07-2000, 07:28 AM   #3 (permalink)
Re: 91 300SE A/C
I've had this car for a month, and it's been like this. This is on any increase of RPM. Someone at my office said there's a switch which kickes the A/C off during acceleration, so the car can have more power. but that doesn't explain why it also stops blowing from the front vent and blows from the defrost vent? The A/C cooling performance, even thought is fully charged and has been inspected by a mechanic is below average.<p>
Old 07-07-2000, 09:17 AM   #4 (permalink)
Re: 91 300SE A/C
On my way to work, the a/c went off when I <br>accelerated then I put my hand on top of the defrost <br>vent and the air was there. Weird. My guess is that<br>when you accelerate, it turns the a/c off and allows<br>fresh air from outside to come in through the defrost<br>vents. Although I don't know what switch your office mate <br>is talking about. I'll try and look for it in the<br>manual if it exists.<p>Have your vents cleaned. Also have you replaced your<br>belts recently ? Mine was really bad and when summer came,<br>my a/c was like blowing hot air. My mechanic changed the <br>belts, checked the freon and cleaned the vents <br>After that, my a/c was ice-cold.<p>Hope this helps.<br>Anton<br>was<br>: I've had this car for a month, and it's been like this. This is on any increase of RPM. Someone at my office said there's a switch which kickes the A/C off during acceleration, so the car can have more power. but that doesn't explain why it also stops blowing from the front vent and blows from the defrost vent? The A/C cooling performance, even thought is fully charged and has been inspected by a mechanic is below average.<p><p>
Old 07-08-2000, 05:54 AM   #5 (permalink)
Re: 91 300SE A/C
: the A/C will kick into the defrost mode (blows from the top vent) on any icrease of RPM. it will blow from the front vent once the engine has leveled off. is this normal with this model?<p>Your default position for the heater air flow is "defrost".<p>Engine vacuum holds it in the other positions, i.e. floor,dash vents.<p>You are losing vacuum to the hetar/ac control system.
Old 07-08-2000, 06:56 AM   #6 (permalink)
Re: 91 300SE A/C
Yes the belt is in very good shape. The A/C was serviced, because I noticed some air bubbles throught the little viewing glass. The Mechanic added about 1/2 can of R-12 because the pressure reading was good, but there are still some bubbles.<br>two questions: how did you clean the vent. do I need to disassemble something? and also if there is a vacuum leak, where can I look for this?<br>thanks,
Old 07-08-2000, 07:00 AM   #7 (permalink)
Re: 91 300SE A/C
Thanks Frank. would you let me know where do I look for the vacuum leak. will this be under he dash or in the engine compartment? and if so in which area?<br>thanks, Shon<br>
Old 07-08-2000, 01:27 PM   #8 (permalink)
Re: 91 300SE A/C
: Thanks Frank. would you let me know where do I look for the vacuum leak. will this be under he dash or in the engine compartment? and if so in which area?<br>thanks, Shon<br><p>I have no idea where the vacuum leak is. You will have to isolate it
Old 07-09-2000, 09:18 PM   #9 (permalink)
Re: 91 300SE A/C
: the A/C will kick into the defrost mode (blows from the top vent) on any icrease of RPM. it will blow from the front vent once the engine has leveled off. is this normal with this model?<p>It absolutely isn't normal. If you have the AC set from the front or floor vents, it always stays there regardless of RPMS, etc<p><br>
