Diff. Swap - Mercedes-Benz Forum
post #1 of 33 (permalink) Old 10-26-2014, 10:17 AM Thread Starter
AlexHasA300SEL's Avatar
Date registered: Aug 2011
Vehicle: 1990 Mercedes-Benz 300SEL M103 3.0L L6
Quoted: 2 Post(s)
Diff. Swap
I have been searching the forums about the long time talked about 2.88:1 differential swapping into the 300se/sel rear end. I see some talk about it and some one will say someone has done it.. but no real info about how it worked out or pictures or anything.
Since its been a few years since those discussions. I thought id ask if anything has change or if anyone could say if its worth doing it.
Have any of you driven one with the conversion?
I am a MB Tech at my dealer and have the tools/rack/resources to do the swap if I want.
Would the bottom end torque suffer THAT much if I swapped in the sd/sdl 2.88:1 diff. In (if I could find one) and did the first gear start mod?
Open to comments, im not looking for tons of power just lower rpms at highway without turning my already underpowered car in to the dreaded 240D. Thanks.
AlexHasA300SEL is offline
post #2 of 33 (permalink) Old 10-26-2014, 05:09 PM Thread Starter
Quoted: 2 Post(s)
No one eh?
post #3 of 33 (permalink) Old 10-26-2014, 05:23 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 384 Post(s)
did you pm the folks in the old threads?
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers.
281lxm is offline
post #4 of 33 (permalink) Old 10-27-2014, 07:40 AM
81126's Avatar
Date registered: Dec 2007
Vehicle: 1985 300SD 1988 560SEC 822 1976 450SEL 1981 300SD
Quoted: 28 Post(s)
doing much the same...
...at least, losing the current diff in the 300SE I'm turning into a 300SD - well aware that the '85 is a Gen 1 and won't fit the Gen 2 chassis, but fortunately both are antilock diffs. Will keep you posted..
Just say no to sparkplugs[SIGPIC]
81126 is offline
post #5 of 33 (permalink) Old 10-27-2014, 12:30 PM Thread Starter
Quoted: 2 Post(s)
Well which cars had the 2.88:1 diff? The 300SD/SDL and the 350SDL? Or no.
post #6 of 33 (permalink) Old 10-27-2014, 04:12 PM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 265 Post(s)
Correct me if I'm wrong, but the physical dimension of the differential on the 300SE/SEL's are smaller than on the V8's. I think they might have different half-shafts as well (lengths). So you may have to think about swapping differentials and half-shafts together.
Dr.Grillz is offline
post #7 of 33 (permalink) Old 10-27-2014, 05:36 PM
Date registered: Nov 2002
Vehicle: '82 500sec euro, '95 Ford F150
Quoted: 105 Post(s)
Not sure about the 300, but the 2.88 is definitely the 1.1liter pumpkin, with the half shafts secured internally with the C-clips.
What pain in the ass, compared to the 1.3 liter pumpkin with the external mounting.
Btw, the 2.88 is available with ABS or no ABS.
roadhouse is offline
post #8 of 33 (permalink) Old 10-27-2014, 05:40 PM
Quoted: 105 Post(s)
post #9 of 33 (permalink) Old 11-01-2014, 06:21 PM Thread Starter
Quoted: 2 Post(s)
Well I dont think the v8s will work. I was thinking more along the lines of the diesel 126 car differentials since the gearing is closer.
post #10 of 33 (permalink) Old 11-01-2014, 09:03 PM
Always Remembered RIP
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 560SEC AMG
Location: Grass Valley, N. Calif. / Gardnerville, Nevada
Quoted: 17 Post(s)
Send a message via AIM to cascade
Don't know if you mean the 2.82 diff actually, the 2.88 never existed as a diff for any w126 so far as I am aware, but it
may have been available for the m103 6 cylinder engines such as the 280 SEL/SE/300SE/SEL with that diff. (Very peppy! (at least in the '85 280SE euro I test drove around San Francisco and around and on Twin Peaks long ago...) though that one probably had a first gear start, I don't know.
A 2.82 diff could swap into a w126 pretty easily but these days they are as rare as hen's teeth.
That said, it is a good mod, and in fact about a dozen+ years ago Carl Genberg, down in Glendale, Ca at the time, ditched the factory 2:47 LSD in his 560SEC, and put in a 2.82. I got a ride in it a couple of times, and WOW !!!!!!! what an experience and an
improvement THAT made. Easy to chirp the tires from a start every time, on Carl's 560 SEC LIKE THAT Especially mated to a first gear start unit that Carl was then selling, to bw members back around 2002-2003. In fact we had a benzworld FGS install party, about 6-7 of them put in out 560SECs in one day at a member's home in San Jose. Most of us have since dispersed.
But then I myself scored a more mild 2.65 diff from a junked AMG 560SEC and had it shipped from the seller in Atlanta, to me out here.
And I can SURE tell you THIS:the combo of the FGS module, along with the 2:65, hooked up to a 300hp 560 sec euro engine, with a Remus muffler and a set of true w126AMG headers and downpipes, REALLY *is* worth it. This picture is BEFORE the front and rear euro bumpers were added.
Took me a long time to find all this, but I sure do love it!
I'm certain you would too. The toughest part, of course is just *finding* all this stuff.
Patience, luck peristance money and good luck will bring it to you.
Jim
<--- superschnelle 300 hp 10:1 ECE euro HV, Hochverdichtung = high compression (11/2011) ... Wie im Freien Fall. Nur horizontal.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." >'='<
cascade is offline
