Where does the vacuum line plug in... - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 11-20-2013, 05:36 PM Thread Starter
Date registered: May 2010
Vehicle: 1989 Mercedes Benz 300SE, 246k miles; 1976 MB 450SL between 95k and 250k miles
Quoted: 15 Post(s)
…the short one that hangs off of the oil vapor retune line that comes off of the valve cover and goes into the air cleaner housing? It's a short line with a rubber fitting on the end shaped like a little flying saucer. I searched everywhere and cannot find a hole to stick it in! Thanks.
By the way, this forum rocks!
the_bends is offline
post #2 of 17 (permalink) Old 11-20-2013, 07:08 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 252 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
IDK 6's that well, or at all, but it sounds like the fuel pressure regulator?
Current Stable:
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers FOR SALE. - PM ME
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #3 of 17 (permalink) Old 11-20-2013, 08:56 PM
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 328 Post(s)
mclare is right, it goes into the back of the fuel pressure regulator which is strapped to the fuel distributor at about 7 o'clock as you view the FD from the driver's side.. If you don't know what it is, look for a cylindrical part about 5" long with a hard fuel line coming out of one end and headed toward the driver's fender, and a hole for your flying saucer at the other end.
luckymike is offline
post #4 of 17 (permalink) Old 11-20-2013, 09:15 PM
GreenT's Avatar
Date registered: Mar 2013
Vehicle: 1995 S500, 1990 420SEL
Quoted: 7050 Post(s)
6 cylinders
8 cylinders
GreenT is offline
post #5 of 17 (permalink) Old 11-21-2013, 12:59 PM Thread Starter
Quoted: 15 Post(s)
AhHa! My FR is plugged
It's got a rubber (black) plug in that hole on the regulator body: no tube extending out from it. So there is nowhere to stick the end of the vacuum line. Funny, my mechanic just stuffed it under the air cleaner, dangling. Guess it's not needed. Hmmm.
post #6 of 17 (permalink) Old 11-21-2013, 03:46 PM
liviu165's Avatar
Date registered: Aug 2013
Vehicle: 1989 MB 420SEL,
Quoted: 333 Post(s)
Everything is needed on these cars, everything has a purpose, but what do I know, I just am a nobody. What I do know is that if your mechanic stuffed it under the air cleaner, you do need ... another mechanic (that does not cut corners).
It will not be easy to get it back into the FPR. I got some back and had the FPR out and it was not easy. When is on the car, is even harder and I would be surprised if you get it in w/o braking it. Examine first the rubber fitting to make sure it not broken before you try to insert it. If it is, don't bother, replace the rubber fitting first with a new one first.
If it was me, I would take advantage that the fitting is out, eaxmine it first, and if needs replacement I would order one/some first and then install it.
liviu165 is offline
post #7 of 17 (permalink) Old 11-21-2013, 03:51 PM
liviu165's Avatar
Quoted: 333 Post(s)
This is the way it should look with the fitting installed. The "saucer" part is inserted, you don't see it.
liviu165 is offline
post #8 of 17 (permalink) Old 11-21-2013, 08:25 PM
GreenT's Avatar
It is, very much so. Listen to liviu165.
GreenT is offline
post #9 of 17 (permalink) Old 11-21-2013, 11:26 PM
Seppo's Avatar
Date registered: Dec 2008
Vehicle: MB 300SE -90, > 500 000 km
Quoted: 6 Post(s)
I drove my 300SE for months and months without that tube attached to the FPR. Did not notice any issues performance- or MPG-wise.
Then I finally bought a new rubber insert (there was actually no difference to the old one I had; probably just gotten loose somehow !) and found out that with reasonable effort, I was not able to get it into the orifice of the FPR (while everything in place in the engine compartment). The lazy man's solution was then to invert the rubber insert, cut the other end enough to fit in the vacuum tube and stick it in (went way easier). That's the way it has been ever since...
W 126 300 SE -90 anthrazite grey, > 584 000 km, DD
W 123 200 D -84 classic white, > 620 000 km, at rest
(W 140 S 320 -95, blue black, > 360 000 km, wife's)
Seppo is offline
post #10 of 17 (permalink) Old 11-22-2013, 03:34 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 383 Post(s)
I cannot tell you the level of foul language trying to get the *&^)*%(_@ back into the FPR with a new rubber insert. Like most, mine was virtually melted/dryrotted away and my line coming off the psgr side valve cover was just sitting inside of it. So I have kite string and scotch tape for this, remove the FPR and try that way or, wait for it,......... removed my belt to the airpump and I am not sure it matters anymore
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers.
281lxm is offline
