Timing off after timing chain replacement - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 08-19-2013, 11:51 AM Thread Starter
Date registered: May 2012
Vehicle: 1985 500 SEL Euro
I just replaced my chain and guides (thanks to this forum--couldn't have done it without!) but the car won't start now. It's sputtering and sounds like it's backfiring.
I lined everything up: at TDC the balancer is at 0, both cam marks line up, chain tight, new tensioner, and distributor pointing to the #1 cylinder.
I even adjusted the distributor-you can pivot it a little before you tighten it down-and used a timing light while someone cranked. The light is hitting the 0 mark every time. It seems like it's the common 180 degrees off problem, but the timing light ruled that out.
I unplugged the coil and cranked it while listening--it had a regular and steady sound, so it seems electrical...
Is there anything I'm missing? I'm stumped!
Last edited by T Ratzlaff; 08-19-2013 at 01:06 PM. Reason: Forgot some information
T Ratzlaff is offline
post #2 of 14 (permalink) Old 08-19-2013, 12:08 PM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 374 Post(s)
wish I could help, curious to see responses. Hope you get what you need quick. My Indy shop did mine and my engine performance showed a marked improvement.
_____________________________________________
1991 560SEC 199 Black/268 Grey, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers.
281lxm is offline
post #3 of 14 (permalink) Old 08-19-2013, 01:33 PM
Date registered: Aug 2012
Vehicle: 1960 280
I just changed my entire camshaft, sprocket and had to take the chain off while doing so and i didnt run into the issue.
did you refer to the manual on how to line up the cam markings and the sprocket markings? i have a m103 engine, so it will be different for me. you might want to look at that. there is no adjustment needed for m103, the EZL makes up for minor adjustments based on what i read...
fizzizist is offline
post #4 of 14 (permalink) Old 08-19-2013, 01:38 PM
Vehicle: 1960 280
This is for my m103 engine that i used...
http://w124-zone.com/downloads/MB%20...03/05-2230.pdf
post #5 of 14 (permalink) Old 08-19-2013, 02:12 PM Thread Starter
The only thing I could find was in the chain replacement section. It showed the cam mark and I lined it up the same way.
I did come across a section on the "TDC transmitter"...wonder if anyone has experience with that?
Thanks for the link though!
post #6 of 14 (permalink) Old 08-19-2013, 02:27 PM
strife2's Avatar
Date registered: Jul 2004
Vehicle: 560SL,380SL
Quoted: 52 Post(s)
The engine will do this if the distributor is 180 degrees off. Make sure you are at the lines AND that the distributor is at the mark correctly.
Homebrew MB First Gear Start!
http://juliepalooza.8m.com/sl/mercedes.htm
strife2 is offline
post #7 of 14 (permalink) Old 08-19-2013, 04:05 PM Thread Starter
OK, here's where I'm at:
Here's the rotor pointing to the notch / #1 cylinder,
Balancer at 0,
and cam mark (I didn't pull the driver side cover to take a picture, but made sure it was in place before putting everything together)
post #8 of 14 (permalink) Old 08-19-2013, 06:12 PM
Date registered: Jan 2010
Vehicle: 1968 gto (sold) , 91 volvo 740, 89 $300TE, 89 560SEC
Quoted: 2 Post(s)
Timing looks ok... You didn't cross wire it did you? Because I have
I would verify spark plug wiring on the cap.
TDC transmitter on front cover just sends its signal to the X11(?) test port on the drivers fender.
p7fan is offline
post #9 of 14 (permalink) Old 08-19-2013, 07:14 PM
strife2's Avatar
Quoted: 52 Post(s)
The plug wires are a good suspect, I've mixed them up too...also, it's been my experience that after a few years, NO amount of care, proper boot pulling tools, and so on will prevent at least ONE wire from going bad when going through a removal/reinstallation cycle. They just get brittle. In the old days, it was a copper wire with a lot of insulation, what can go wrong? Now, it is a complex woven resistance element surrounded with even MORE insulation, and the underhood temperatures, once high, are now brutal.
strife2 is offline
post #10 of 14 (permalink) Old 08-19-2013, 07:37 PM Thread Starter
The wires are definitely in the right sequence. That's a good point though--I'm going to check each one for spark. I just assumed that if they worked before, they'd work after. If anything, that'll be another part of the equation to rule out.
