Headlight Switch Replacement - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-15-2013, 09:24 PM Thread Starter
Date registered: Jan 2013
Vehicle: '91 350 SD, '06 S2R 1000, ’12 848 Evo Corse SE, '73 CB 350/4
My headlight switch is broke (requires some finesse to get the low beams to 'catch') and I have a replacement for it. I know it takes a little muscle to pull the knob off and that the switch is held to the bezel (black plate?) with a retaining nut behind the knob, but how do I remove the bezel? In pictures it looks like there are screw tabs on the back of the bezel. Please tell me I don't have to remove the dash!
Thanks in advance for any guidance!
3p0ch is offline
post #2 of 14 (permalink) Old 03-15-2013, 09:33 PM
Seltsamen mann's Avatar
Date registered: Jun 2012
Vehicle: 1987 W201 190E 2.6
No, you don`t have to remove the dash. Simply remove the carpeted panel underneath the dash, then remove the knob on the switch by yanking on it, then undo the nut, then push the switch out the back. It`s specifically wired and I`m not sure there`s a plug further back for said wires so you`re best marking the wires before you remove them, otherwise you`ll be up the sh*t.
My Mercedes is driving me around the benz..
Seltsamen mann is offline
post #3 of 14 (permalink) Old 03-15-2013, 10:07 PM
Date registered: Oct 2010
Vehicle: 560 SEL (1991)
Just make sure you get an OEM switch! Do NOT get a URO switch or any other brand. Trust me.
With that said, I found it easier to do with the cluster out. Never tried from below. Its not easy but not too hard to do. The plug is keyed, so not worry there. Its also HUGE. The connector is the same diameter as the very large switch assembly. So dont be confused when you look at things. To pull that switch knob off I used a soft rage and a pliers.
When you re-install, make sure you "twist" the switch into place. You will see small metal tabs. I bent my forward (I think) a bit to make sure the new switch bit into place tighter. The switch body is keyed, but can go in the wrong way (upside down).
unity is offline
post #4 of 14 (permalink) Old 03-16-2013, 12:42 AM Thread Starter
Phew! I got the MB switch, not the URO! I must've had a few extra pennies in my account when i placed the order becuase i know autohausaz sells both, and the uro is half the price. And yes, I was quite surprised by its size when I unboxed it.
I appreciate the suggestions, mann and unity! I'm probably going to attempt the under-dash method tomorrow. There are really only two things I hate messing with on vehicles: dashes, and door panels!
3p0ch is offline
post #5 of 14 (permalink) Old 03-16-2013, 04:44 AM
281lxm's Avatar
Date registered: Dec 2011
Vehicle: 1991 560 SEC 1994 E500 2014 E350 Cab
Quoted: 370 Post(s)
dont break your neck, retract that steering wheel, and pull out the cluster. This way you do not have to tear cartilege in you back and ribs getting under the seat. face up. Search cluster removal here or on mercedessource.com under technical videos. it is very easy.
_____________________________________________
1991 560SEC 199 /268, 17" RS90'S, Eibach springs, Bilstein HD shocks, Custom rear sway bar, Euro Headlights, Custom ceramic coated headers and down pipes with stainless dual exhaust, W140 glass sunroof, dog ear trunk spoiler, OEM Skid Plate, Euro bumpers.
281lxm is offline
post #6 of 14 (permalink) Old 03-16-2013, 09:16 AM
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler
Quoted: 875 Post(s)
I replaced mine last year, it'll take you a whole 10 minutes if it's a "plug n play", pull the cluster out, find the headlight assy cable and unplug, Rag with pliers to pull switch knob, undo the nut holding the switch, remove and install new switch in reverse order. no dash disassembly required except for pulling the cluster out of the way
IF you have the older switch (GenI) you'll have to swap out the wires one by one, you'll be able to tell by looking at the cable at the switch
Some days it's just not worth chewing through the restraints
My Stable:
'91 560SEC
'91 300SE (sold)
'98 Yota RAV4
'02 S-10 Truck
'72 SeaBird boat, overhaul on hold
Dif-tor heh smusma
wooky_chew_bacca is offline
post #7 of 14 (permalink) Old 03-16-2013, 12:46 PM Thread Starter
Finished!
Holy crap! I had no idea the headlight switch was supposed to be so crisp and, well, functional! I guess mine was a sloppy mess since I got the car...and the old switch sounds like a can of sand when I shake it. Obviously a bad thing. The new switch sounds like beautiful silence.
I ended up pulling the cluster with some homemade coat hanger pullers. I was fairly worried because my cluster was rather stubborn, not the easy pull described or shown in videos. But I got it to budge with a few healthy tugs. My switch connected with a simple (large!) plug, easy-skeezy.
The only problem I had was a split plastic shield on a power wire on the tach side of the cluster. When reinstalling, the metal connector slid forward of the shield and arced on the back of the cluster popping the fuze for the dome light. Some electrical tape on the shield and a new fuze in my number 2 slot and everything seems to be working, thank the maker! Next time I'm going to disco the battery first!
Thanks to everyone for the guidance and suggestions!
3p0ch is offline
post #8 of 14 (permalink) Old 03-16-2013, 12:55 PM
Quoted: 875 Post(s)
Yup, I still have my trusty coat hanger pullers too, and that wire was the hot for the clock, had to tape mine too (OH, I forgot to mention the plug is/was an oversized one )
My Stable:
'91 560SEC
'91 300SE (sold)
'98 Yota RAV4
'02 S-10 Truck
Dif-tor heh smusma
post #9 of 14 (permalink) Old 03-16-2013, 01:11 PM Thread Starter
Yeesh, that's a lot of juice for a damn clock!
3p0ch is offline
post #10 of 14 (permalink) Old 03-16-2013, 01:16 PM
Quoted: 875 Post(s)
Made ya jump too I'll bet (don't ask me how I know lol) 12V always hot from the battery.
And those "special tools" look just like mine
My Stable:
'91 560SEC
'91 300SE (sold)
'98 Yota RAV4
'02 S-10 Truck
Dif-tor heh smusma
