Attempted fuel filter swap today. I need help please. - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 02-26-2013, 11:24 AM   #1 (permalink)
Date registered: Feb 2013
Vehicle: 1990 560 SEC, 2005 ML350
Hello,
I attempted to change out my fuel filter today, but I hit a road block. I tried loosing the lines from the filter at the points I circled in red, but the lines did not want to give. I didn't want to do something stupid, so I reassembled it and came here.
My question is, 1) is this the correct procedure? 2) Will a bunch of fuel come out after removing these lines, or is it just a small amount? Any advice/tips are highly appreciated!
Cheers
Attempted fuel filter swap today. I need help please.-car-010.jpg   Attempted fuel filter swap today. I need help please.-car-011.jpg
352pro is offline   Reply With Quote
Old 02-26-2013, 11:55 AM   #2 (permalink)
rumb's Avatar
Date registered: Oct 2012
Vehicle: Current MB's 1968 250S, 1991 300se, 1998 SL500. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Make sure you put a 2nd wrench on the ''nut' behind the main one in the second picture. I cant see if there is one on the filter housing. Just use a longer breaker bar and pull steady. There will be some gas come out. Best if you replace the 2 metal washers on the banjo fitting though they can be reused if look ok. "lefty loosy" - when upside down can get confused. a little kroil never hurts either.
rumb is online now   Reply With Quote
Old 02-26-2013, 02:25 PM   #3 (permalink)
mclare's Avatar
Date registered: Aug 2008
Vehicle: 91-560SEC w/Custom Built Motor; 90-560SEL; 87-560SEC
You need to clamp off the line coming down from the tank or it will all leak out onto you.
You need to be careful not to pinch or damage that line either or you will ruin it and have leaks there too.
The best procedure is to drain all of the fuel out of the tank by siphoning it all out, then loosen the line coming down from the tank and drain the rest of it out into a pan, then proceed to rebuild the fuel filter assy and pumps. I would do it all and do it right by also replacing the fuel regulator also (The one by the filter, not the one under the hood. That will help with starting up, as it's a one way check valve with a rubber diaphragm that goes bad).
Do it once, Do it right! I think I did a whole thread on R&R the fuel system.
Current Stable:
91-560SEC - Coupe - 199/267 - Custom Built Motor - Highly Modified Coupe
90-560SEL - Sedan - 199/267 - Stock
87-560SEC - Coupe - 040/264 - For Parts
Sold:
97-500SL - Roadster - W/AMG Sport pkg.
87-420SEL - Sedan
mclare is offline   Reply With Quote
Old 02-26-2013, 03:06 PM   #4 (permalink)
ABQ450SLC's Avatar
Date registered: Jun 2005
Just did this. No need to drain all gas or clamp any hoses. Remove the cap to relieve pressure. Only gas that will come out is the gas in the filter itself. Mine was completely full and about 2 cups came out.
1978 450 SLC (EURO)
1987 420 SEL
1972 MGB (RHD)
1986 Jeep Grand Wagoneer
ABQ450SLC is offline   Reply With Quote
Old 02-26-2013, 04:14 PM   #5 (permalink)
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1973 450SE
I would add a caution to be careful with the metal line in your first picture. I accidentally scored the surface of mine where the copper washer fits against the banjo. Got a nice fine stream of fuel shooting right through that tiny score mark!
I had do very carefully file the surface flat again. It was a real pain.
luckymike is offline   Reply With Quote
Old 02-26-2013, 07:03 PM   #6 (permalink)
mclare's Avatar
This is true only IF you are only doing the filter itself. If, as I did, you do everything, (Filter, pumps, and regulator) then you need to either drain or clamp.
When I do a job, I do all of the components at once because I do not like to go under and do it twice. I have learned the hard way.
Old 02-27-2013, 03:56 AM   #7 (permalink)
Date registered: Jul 2010
Vehicle: 1991 560SEC
I found it was much easier to do this with the entire fuel block (pumps, associated lines and filter) removed from the car working on a bench and I could inspect everything that needed to be replaced rather than being on the concrete floor on my back.
slow&rusty is offline   Reply With Quote
Old 02-27-2013, 07:22 AM   #8 (permalink)
reno4u2's Avatar
Date registered: Dec 2009
Vehicle: 1988 560SL (California Model)
+1 Great product. Glad to see others have picked up on it.
Penetrating-Lubricating Oils
reno4u2 is offline   Reply With Quote
Old 02-27-2013, 07:57 AM   #9 (permalink)
VaiFanatic's Avatar
Date registered: Aug 2010
Vehicle: '84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '08 BMW Z4 3.0si, '09 E350
Location: San Antonio, Texas/Pensacola, Florida/Neustadt a.d. Aisch, Deutschland
Send a message via Skype™ to VaiFanatic
This is probably the most brilliants approach I've seen. I must pay you homage with a case of beer of your choice.
'85 Euro 190E 2.3-16 "Valvy" - Driving from Cali in June
'84 Euro 500SE ~96k miles *Duriel, the desert prince*
'51 Euro 170S *Being reborn*
'97 Jeep Wrangler Sport ~40k miles
'08 BMW Z4 3.0 si ~14.3k miles
'09 E350 ~48k miles
---> 1951 170S Restoration/Updating Thread!
http://www.benzworld.org/forums/w126...y-project.html
---> 1984 500SE Thread!
http://www.benzworld.org/forums/w126...se-thread.html
VaiFanatic is online now   Reply With Quote
Old 02-28-2013, 04:18 AM   #10 (permalink)
Thank you, everybody! While it certainly makes sense to do all of these at the same time, I'm just going to swap out the fuel filter at the moment. Perhaps in the next few months I will swap out the rest, but at the moment I am trying to minimize costs (per trying not to upset the wifey) and focus on the main areas of concern, particularly since I'll be getting the timing chain replaced soon. Thanks for all of your pointers! I will be referencing these tips in the very near future.
Bookmarks
