Diff Ratio - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-11-2012, 06:49 PM Thread Starter
TUF500's Avatar
Date registered: Sep 2012
Vehicle: 84 500SEL
Diff Ratio
Wondering if any one knows were i can get diff gears for a 500sel online.
TUF500 is offline
post #2 of 8 (permalink) Old 09-11-2012, 07:32 PM
Date registered: Jun 2011
Quoted: 84 Post(s)
I would think your best bet would be a junkyard
w126Sam is offline
post #3 of 8 (permalink) Old 09-11-2012, 09:56 PM
Date registered: Apr 2006
Vehicle: 1983 380SL, 2000 S430, 1991 420SEL (retired) - RHD
Quoted: 221 Post(s)
Smile Diff gears
Are you sure you need diff gears- not just the bearings? The diffs are pretty bulletproof.
Aussiemerc is offline
post #4 of 8 (permalink) Old 09-11-2012, 11:58 PM Thread Starter
TUF500's Avatar
Vehicle: 84 500SEL
I want to change the ratio
TUF500 is offline
post #5 of 8 (permalink) Old 09-12-2012, 05:15 AM
alydon's Avatar
Date registered: Mar 2004
Vehicle: 84 500SEL AMG, 90 560SEC AMG, 85 500SEC AMG Widebody
Quoted: 51 Post(s)
Stock Gen I 500SEL ratio is 2.24. Finding a 2.65 or 2.82 diff is very difficult. Took me over a year to find a 2.82 diff for my 84 500SEL. Of course, I had to have limited slip and the diff had to have ABS, further limiting availability. If your car has ABS, you need a diff with the ABS gear on the pinion shaft, or you need to buy the ABS gear and have it pressed on. You can't use the ABS ring gear on your current diff pinion shaft - wrong # of teeth. If you don't have ABS, an option is to find a 2.65 LS diff from a 450SEL 6.9 all of which came with a 2.65 ratio and the diff pumpkins are identical to a Gen I diff. However, if you need ABS, again, you have to install an ABS ring gear (only Euro 6.9's were optional ABS - no US 6.9's had ABS).
Look at this post I made for more info:
http://www.benzworld.org/forums/w126...ferential.html
Here is a 2.65 R&P set from a 6.9 for sale by RennTech - $600 that would work in your Gen I pumpkin:
http://www.ebay.com/itm/MERCEDES-116...41ba86&vxp=mtr
One last point - if you change the diff ratio, your speedo will be inaccruate by the % change in ratio (i.e. from a 2.24 to a 2.65 = 18% error in speed reading). You have to live with it, have your speedo re-calibrated by a speedo shop or install a Dakota Digital module that alters the speed reading.
Al
Al Lydon
Atlanta, GA
1984 W126 500SEL AMG -5.4L, Sebring exhaust, full suspension, 2.82 LSD, 8"/9" wheels, Recaros, door wood, Clarion rack stereo. Anthracite Grey 172, Black Interior
1990 560SEC AMG - 6.0L, Sebring, suspension, 2.65 diff. Arctic White/Blue
1985 500SEC AMG Widebody, 199/278, 5.4L, full mods
Priors:
1994 E500, Polar White/Grey
1990 560SEC, Black Pearl/Black (Japan)
1991 560SEC, Black/Palomino
1961 W111 220SEb Coupe
1987 W126 560SEC
1995 W124 E420
1996 R129 SL320
alydon is offline
post #6 of 8 (permalink) Old 09-12-2012, 06:32 AM Thread Starter
TUF500's Avatar
Vehicle: 84 500SEL
there is nothing off the shelf cause i was thinking of going with 3.40 or somthing around that mark
TUF500 is offline
post #7 of 8 (permalink) Old 09-12-2012, 08:51 AM
alydon's Avatar
Quoted: 51 Post(s)
Just my opinion, but anything around 3.40 is not very driveable. Besides, there are limited diffs in existence higher than 2.82 from Mercedes for the W126 except for the ultra rare AMG Gleason-Torsen diffs that were available in the mid-late 80's. The early Euro 380's may have had a ratio over 3:1 that might work. Some owners have tried inserting a Quaife diff in the 126 carrier, but I have not seen a successful attempt yet.
Al
Al Lydon
Atlanta, GA
Priors:
1987 W126 560SEC
1995 W124 E420
1996 R129 SL320
alydon is offline
post #8 of 8 (permalink) Old 09-12-2012, 06:57 PM
oisaj_dude's Avatar
Date registered: Oct 2006
Vehicle: '83 380SEC AMG'ed euro, '92 500SL, '90 300e 4matic DD
Quoted: 40 Post(s)
You can get a 3.27 out of an early euro 380, usually ABS equipt. It'll need to be out of a '79-'80.
If you want out of the box Renntech has what you need. They have some left over from when they would swap in Gleason carriers and change the gears. They have had these for sale for quite a while now, don't be afraid to make them an offer (Really nice guys to deal with, though a bit pricey):
MERCEDES 126 CHASSIS SCLASS RING AND PINION 3.27 RATIO | eBay
Not sure where you can get the 3.47, I might have that in a 280 I'll be parting. It would have the high gearing but I don't think it has ABS.
oisaj_dude is online now
