As some of you fellow forum members know, I am going to install a Euro Reiserechner/Trip Computer into a late U.S market Gen2 W126. This thread will cover the entire process of the installation and will cover the M116/M117 V8 engines and only applies to the U.S Gen2 year models starting from 8/85 and up.
There are 2 specific models that will be discussed here and they are the 420/560SEL/SEC. This write up does NOT cover the Gen1 cars nor the Gen2 diesel and inline 6cyl gas models of the W126.
Throughout the installation I will provide pictures and detailed termination points of the wiring harness assuming you have the original harness and brain box with the instrument cluster.
There are 5 components that make up the trip computer.
They are:
1. Instrument cluster
2. Trip computer brain box
3. Complete wiring harness
4. Control switch in center console
5. Center console shifter wood(cut out for control switch)
NOTE: There are no additional sensors needed on the Gen2 models as the TC will gather information through the instruments in the cluster and the existing sensors/electronics.
Lets begin with the Trip computer I will be working with during this install.
My set up was removed from a 1988 560SEC. I don't know anything about the car it was removed from but my cluster was equipped with the U.S. version speedometer and the trip computer displays in kilometers. Though the unit I have was removed from a 560, it had the 160mph face plate instead of the 170mph plate that the 560SEL/SEC had from the factory. You can keep the 160mph odometer or swap it out if you choose to do so.
I wanted to keep the original 170mph face plate with the odometer from my 560 and during the disassemble process of the TC cluster I discovered that not only could I swap out the odometer but I could also transfer the digital clock as well, the TC will function without the clock but will not be accurate in some modes such as time from/to destination.
Once I had the cluster back together it was time to check out the function of the instruments. I installed the cluster and hooked all of the factory connectors back in place with the exception of the TC harness. All systems were functioning correctly except the low fuel light no longer worked. Another cool feature that I really like about the TC is the placement of the Tachometer on the left side. The economy gauge was deleted and the fuel gauge went in it's place.
I am also missing one very important part from the list above and that would be the entire main wiring harness to my TC and is the soul purpose of this thread to begin with but within this comes an advantage, to possibly help others through the installation steps of the TC should they decide to do so.
A forum member was kind enough to send me the wiring harness and brain box to his TC to use/copy, that's right, I am going to make one myself right here but more about that will be posted when I am more prepared.
I have gathered some very useful information about the TC already but there's a long way to go yet.
I will start off with some pics of the TC cluster, shifter wood and control switch before I disassembled anything. Here you can see the arrangement of the instruments in the TC cluster.
They are:
