What did you do to your 126 today? - Page 26 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 01-07-2013, 06:04 AM   #251 (permalink)
Peter R.'s Avatar
Date registered: Jun 2010
Vehicle: '95 993 / 2011 F150 Raptor SC / Viano / 500 SEC
Finally got around to install the new fuel acumulator. Guess what ? Starting issues fixed !
Peter R. is offline   Reply With Quote
Old 01-07-2013, 06:42 AM   #252 (permalink)
wooky_chew_bacca's Avatar
Date registered: Oct 2009
Vehicle: '91 300SE
Oh ok Keith, thats good too, a Salute to you for serving our Country, my Dad retired from the Navy in '68 and my son, ironically both with the same name and also a Hosp Corpsman is at Norfolk right now. I did 4 years in the Army
Chuckler3, when mine flares on upshift changing the filter always fixed that
My Stable:
'91 300SE
'98 Yota RAV4
'72 SeaBird boat, overhaul on hold
wooky_chew_bacca is offline   Reply With Quote
Old 01-07-2013, 09:14 AM   #253 (permalink)
jsebastian's Avatar
Date registered: Sep 2011
Vehicle: 1967 250 S (sold) 1986 560 SEC 1987 560 SL
Replaced pumps, filter and accumulator. Took a short gas shower as forgot to loosen gas cap before cracking lines. Gas is not a great cologne though it smells better than I do after working on the car. Hardest part was routing the lines/wiring so the shroud would fit back. No more gas dripping!
Removed, cleaned and oiled hood latch assemblies to solve a hard-to-close problem. Ended up putting spacers above striker bars so they would "reach" further into the latch mechanism. So much easier to close now. Forgot to mention my botch on this repair: dropped two of the striker bar bolts into the engine. Must have spent an hour searching for them with a light and my fingers probing around like some crazed proctologist. Jumped in the car, did some quick, jolting stops to make them fall out...nothing, never found 'em! Fortunately, Home Depot had the correct sizes, albeit with Phillips instead of hex heads. Never thought I'd buy parts for my car at a home improvement store!
G'day, all,
John
jsebastian is offline   Reply With Quote
Old 01-07-2013, 03:33 PM   #254 (permalink)
Date registered: Oct 2012
Vehicle: 1984 300SD W/5 cylinder engine; KMZ MT-16 Motorcycle
Just driving around in the rain today...listening for the unusual in a remarkably good Diesel engine. Fuel gauge still quirky...have no idea how much fuel is in the tank after the return line popped off the injector last week and for all I know laid a Diesel trail all the way to Lake Forest Park...! Soon...very soon, must fix.
Keith Gilbert is offline   Reply With Quote
Old 01-07-2013, 04:35 PM   #255 (permalink)
Date registered: Feb 2009
Vehicle: 1983 300 SD, 1991 420 SEL, 1979 300SD
changed the transmission mount on my SD today. had a feeling it was causing the hot idle shakes (since it's not so pronounced in the winter time). sure enough it greatly decreased (almost totally removed) the shake (now i don't get embarrassed at a stop light ) . the old mount was very squishy and some of the rubber came off stretching like chewing gum
et7724 is offline   Reply With Quote
Old 01-09-2013, 07:00 AM   #256 (permalink)
My service dog (GSD) was getting neurotic in the back seat...saved the day for both of us by 'discovering' pheromone spray...no harm to the SD and no more tense, neurotic, and agitated dog...amazing.
I think it is the small motor sounds that set her off...fans, etc., but I'm thinking that not having a hood pad over the motor may be a part of the problem...must get to putting in a new one but it's raining today...maybe tomorrow afternoon will work.
Old 01-12-2013, 07:02 PM   #257 (permalink)
vdubpower's Avatar
Date registered: Nov 2003
did a few things over the past few weeks
new brakes, pads and rotors
detailed the car, and decided to try to polish the air cleaner lid, went pretty well,
Mothers metal polish is quite good, used it on the 3 piece amgs
and got a dyno
186 hp to the wheels, coverts to around 230 crank
235lb/ft torque to the wheels around 290 crank
i think thats damn good for a 28 yr old car
also went thru some federalization papers, found the ship the car was sent on from germany
the venus diamond
sounds like a stripper/porn star name.....awesome
also had the e63 dyno'ed
What did you do to your 126 today?-blue-benz.jpg   What did you do to your 126 today?-venus-diamond-7-9-97.jpg   What did you do to your 126 today?-279866.jpg   What did you do to your 126 today?-279863.jpg
1985 500SEL Euro Nautic Blue - A Classic Beauty
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline   Reply With Quote
Old 01-12-2013, 07:06 PM   #258 (permalink)
Premium Member
Date registered: Mar 2010
Vehicle: 560SEC
Premium Member
and got a dyno
Good day!
What engine configuration is yours?
Stock US 500? Tri-Ys?
Do you know which model dyno it was?
Dyno plot is handy with the AFR for reference also.
Tj
Tom Johnson, Phoenix, Az
1988 560SEC (In family since 1990) / Frontier / 240Z / ZHP Coupe
Hellwig Swaybar / H&R / SLS Damper Mod / FGS / Shadowline
EU bumps pending, Tri-Y bought,
tjyak50 is offline   Reply With Quote
Old 01-16-2013, 07:02 PM   #259 (permalink)
Premium Member
Vehicle: 560SEC
Premium Member
I made good w126 progress today.
Fixed my failing fuel inlet line with Swagelok Stainless Tube connectors and stuff.
Then tackled my lack of footwell heat by inserting a bit of safety wire in the connection from the Vac pod to the actuator since the connection was just pulling apart..
Then stopped by Andy's shop and checked on his progress.
Crazy guy is putting (put) a 5Cyl turbodiesel into an SEC.
Old 01-16-2013, 07:51 PM   #260 (permalink)
127.0.0.1
VaiFanatic's Avatar
Date registered: Aug 2010
Vehicle: '84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '08 BMW Z4 3.0si, '09 E350
Location: San Antonio, Texas/Pensacola, Florida/Neustadt a.d. Aisch, Deutschland
Send a message via Skype™ to VaiFanatic
Attachment 490037
Mine doesn't look quite this bad, but it's getting there. Where'd you get the Swagelok stuff? Was the installation difficult? I'm assuming you unplugged the relay, ran the car dry, then clamped the main line.
'85 Euro 190E 2.3-16 "Valvy"
'84 Euro 500SE ~96k miles *Duriel, the desert prince*
'51 Euro 170S *Being reborn*
'97 Jeep Wrangler Sport ~40k miles
'08 BMW Z4 3.0 si ~14.3k miles
'09 E350 ~48k miles
---> 1951 170S Restoration/Updating Thread!
http://www.benzworld.org/forums/w126...y-project.html
---> 1984 500SE Thread!
http://www.benzworld.org/forums/w126...se-thread.html
VaiFanatic is online now   Reply With Quote
Bookmarks
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
281lxm
