My 560 SEC restoration thread - Page 2 - Mercedes-Benz Forum
post #11 of 48 (permalink) Old 04-05-2012, 11:12 AM Thread Starter
Date registered: Mar 2009
Vehicle: 1988 Mercedes 560 SEC (UK spec)
Latest pics...
Here are the two boot floor sections (left and right) that need replacing. They incorporate a vent hole which the bumper slides over.
Here's the original left side after it was cut off!
The RHS is worse. I can't wait until that one is out. Final image of where we are on the LHS.
Most of the new floor section I bought was put in, but the way it's designed to fit means that it should've fitted inside the rear wing - meaning it would've been impossible to just put it straight in without taking the whole wing off. Since it's not rusty, there isn't really any point, so Mick cut it at the point where it connected to the rear wing and then welded it in place. The big challenge was making sure the vent was in the correct position so the bumper still fits right. We think the bumper may have been warped slightly over time by the rust/movement of the original vent (it looks slightly wonky on one side), but hopefully it should still fit OK.
Looks like by next week, both sides should be back together and painted. Then I can move onto the *really* nasty stuff around the rear window. I'm hoping that won't be too bad, but I can't be sure until the window is out.
chris560sec is offline
post #12 of 48 (permalink) Old 04-05-2012, 01:22 PM
Grumpy560's Avatar
Date registered: Aug 2009
Vehicle: 1989 560SEL W126, 1989 ford ranger
I like how this is turning out. Great work. Have you looked in the trunk under the back window to see how bad the rust is there?
1989 560SEL
702 Smoke silver
Grumpy560 is offline
post #13 of 48 (permalink) Old 04-05-2012, 03:44 PM Thread Starter
Thanks, I'm pretty pleased with it so far. Under the trunk looks OK - except if I look through the holes to the base of the window, which appears to be quite rusty, but it's difficult to see. From the top, both inside and out, it looks fine - so I think it's mainly rusty along the seam where the window rests. I don't think I'm going to see it properly until I get the window out though.
post #14 of 48 (permalink) Old 04-06-2012, 09:57 AM
~BANNED~
Date registered: Jan 2011
Vehicle: 2008 C200K (W204) & 1998 SL500 (R129) Imperial Red
Quoted: 25 Post(s)
nice work.. will be looking forward to seeing how it turns out
MafiaDON is offline
post #15 of 48 (permalink) Old 04-06-2012, 03:50 PM
sphinxrider's Avatar
Date registered: Oct 2007
Vehicle: 1987 300SDL
Quoted: 5 Post(s)
Good stuff!
"Sir, the Mafia has arrived."
sphinxrider is offline
post #16 of 48 (permalink) Old 04-07-2012, 09:59 AM
NEZ
NEZ's Avatar
Date registered: Apr 2012
Vehicle: 1986 Mercedes Benz 560 sec Lorinser
Looks great so far.
As to the rear window, they all seem to leak at both corners at this age causing very sneaky rust . . . With my´86 560 sec i had to replace the entire sill due to rust.
NEZ is offline
post #17 of 48 (permalink) Old 04-07-2012, 01:41 PM
Date registered: Jan 2006
Vehicle: SL500 (R129), 500 SEC (W126)
Quoted: 6 Post(s)
Those wheelarch repair panels are a big find, thank you for that. I think I'll watch to see how you get on before tackling similar work myself. I could do with new doors, too.
JJRodger
'99 SL 500
'93 E300 D T
'90 190
jjrodger is offline
post #18 of 48 (permalink) Old 04-08-2012, 03:03 AM
Date registered: Jan 2010
Vehicle: 1989 560 SEC (Euro)
Hey, I've got this job coming somewhere in the future... Did the 500 wheel arches fit no problem? And are they the same width as the old ones?
Front arches are wider on the 560 compared to the "lesser" models. In a similar vein the ebay ad includes many models, but not the 560. What I'm wondering is, are the parts compatible.
Jupix is offline
post #19 of 48 (permalink) Old 04-08-2012, 03:47 AM
Crusty rusty's Avatar
Vehicle: 1982 500SEL; 1987 Mazda B1600; 2001 Holden Vectra 2.6L
Nice work man, good to see a decent resto in progress
1982 500SEL with free lifetime supply of rust
The rebuild:
http://www.benzworld.org/forums/w126...2-500-sel.html
Crusty rusty is offline
post #20 of 48 (permalink) Old 04-08-2012, 04:47 AM
Greeney's Avatar
Date registered: Jun 2003
Vehicle: 300GD 5 dr 1987, W126 420SE, W126 560SE
Quoted: 75 Post(s)
Send a message via Skype™ to Greeney
chris560sec I am only an hour down the road to you, if you need anytyhing from my parts motor just say, it is an SE though but lots will fit.
Great job so far though, I set up a Facebook fan page for my ongoing sagas
https://www.facebook.com/W126Helga
Dr Nicholas Greene
www.126-Sclass.com
www.oldfrenchcars.com
Pompadour, FRANCE
Kent, UK
Greeney is offline
    200,220,230 Petrol Restoration Thread Mystere485 W123 E,CE,D,CD,TD,TE Class 3 02-22-2015 06:58 AM
    '95 S420 Restoration/Repair Thread tleehelen W140 S-Class 1 09-25-2011 01:01 AM
    W116 300SD restoration thread. PzGren W116 S, SE, SEL, SD Class 2 09-25-2010 03:59 PM
    Another W123 restoration thread jaco W123 E,CE,D,CD,TD,TE Class 22 05-03-2010 01:13 PM
    The Recaro's Have Landed!!! - Another Restoration Thread. mclare W126 S,SE,SEC,SEL,SD,SDL Class 80 04-14-2010 02:22 PM
