84 300sd compatible Climate Control? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W126 S,SE,SEC,SEL,SD,SDL Class
Old 02-10-2012, 10:29 PM   #1 (permalink)
Date registered: Jul 2003
Vehicle: '84 300SD
re CLIMATE CONTROL for 84 300sd...Is 126-830-0285 the only compatible model #, or will 123-830-1285 do just as well?
JohnFitzpatrick is offline   Reply With Quote
Old 02-11-2012, 04:40 AM   #2 (permalink)
Vehicle: 82 300D W123, 92 300E 2.6 W124, 90 260SE W126, 94 S280 W140, 10 E300 W212, 81 300SD W126
Yes they are interchangeable, you'll just have to take off the plastic panel at the front of the one with the 123 part number, which is held by 2 or 4 screws. I used it to replace the broken Climate Control on my 300SD.
81 300SD W126
82 300D Euro W123
92 300E 2.6 W124
90 260SE W126
94 S280 W140
10 E300 Avantgarde W212 (Dad's)
ronw123w124 is offline   Reply With Quote
Old 12-19-2012, 03:26 AM   #3 (permalink)
ikeepzitclean's Avatar
Date registered: Sep 2012
Vehicle: '84 300SD
although the unit itself and plugs look identical on the w123 and w126 ACC unit, the internals are different on the boards.. so technically i doubt they can be interchangeable. anybody?
Andre
'84 300SD 145K
'84 300D Turbo 350K
'88 Ram50 2.0L 5-spd. 205K on chassis, 0 on motor (completely rebuilt top to bottom)
...the 14 cars or so I had prior are gone so they dont count
ikeepzitclean is offline   Reply With Quote
Old 12-19-2012, 07:09 AM   #4 (permalink)
The 123 climate controls works on my 300SD the way they should.
Old 12-19-2012, 06:35 PM   #5 (permalink)
Vehicle: '84 300SD
i have a w123 and w126 unit and both are 1984.. i plugged them in out of curiosity and they both seem to work, but how come they have diff. internals then? side boards are identical but main and "daughter board" are different (w123 CC has 4 relays things and w126 has 6). im confused now..
Old 12-20-2012, 10:24 AM   #6 (permalink)
mclare's Avatar
Date registered: Aug 2008
Vehicle: 91-560SEC w/Custom Built Motor; 90-560SEL; 87-560SEC
Have you compared the schematics side by side?
I don't have a 123 or manual set for a 123 so I cannot, but if someone does, I can compare them and give a definitive answer.
Current Stable:
91-560SEC - Coupe - 199/267 - Custom Built Motor - Highly Modified Coupe
90-560SEL - Sedan - 199/267 - Stock
87-560SEC - Coupe - 040/264 - For Parts
Sold:
97-500SL - Roadster - W/AMG Sport pkg.
87-420SEL - Sedan
mclare is offline   Reply With Quote
Old 12-21-2012, 10:50 PM   #7 (permalink)
Vehicle: '84 300SD
yes i compared the CC units side by side and the 2 internal boards I mentioned above look different and even the 5 switches on each board have diff soldered points..
see pix attached:
left picture - w126 CC is on the left and w123 CC on the right
right picture - fully disassembled w126 CC is on bottom and w123 CC is on top
84 300sd compatible Climate Control?-img01459-20121218-1809.jpg   84 300sd compatible Climate Control?-img01456-20121218-1808.jpg
Old 01-17-2013, 12:59 PM   #8 (permalink)
Vehicle: '84 300SD
what do u think Mike? cuz i just picked up a few CC's from the JY.. 1 is a 126 and the other's are 123s.
Old 01-17-2013, 01:47 PM   #9 (permalink)
Grumpy560's Avatar
Date registered: Aug 2009
Vehicle: 1989 560SEL W126, 1989 ford ranger
From what I have been reading about the CCU for the W126 is that in the early gen1 there was a problem with the circuit board getting fried when the aux water pump failed thus burning the board up, I don't know if this problem existed in the W123's or not. From my understanding this problem was solved by installing a protective circuit into the CCU itself sometime in the later gen1 models and remained so into the gen2 W126 models until the end of production. I have read this somewhere in a thread but I can't seem to find the same one again.
This would explain why the early gen1 circuit boards look different than the later gen1 boards. I know for a fact that gen1 CCU will not work in a gen2 or the other way around and the gen1 circuit board looks nothing like my gen2 board, not even close.
1989 560SEL
702 Smoke silver
Grumpy560 is offline   Reply With Quote
Old 01-17-2013, 02:27 PM   #10 (permalink)
Vehicle: '84 300SD
I see what ur saying.. and I know there's a diff. between gen 1 and 2 w126 CCUs. but what we were trying to figure out was the difference between w123 and gen 1 w126 CCUs and if they are interchangeable, which I doubt (based on da internals)
Bookmarks
300SD climate control issues? retho78 W126 S,SE,SEC,SEL,SD,SDL Class 17 02-22-2011 05:51 AM
79 300sd: location of climate control relay? Linus W116 S, SE, SEL, SD Class 4 06-04-2009 05:52 PM
Climate control 300SD bblood W126 S,SE,SEC,SEL,SD,SDL Class 4 12-16-2004 06:28 PM
83 300SD climate control scargo W126 S,SE,SEC,SEL,SD,SDL Class 0 12-02-2002 06:30 PM
83 300SD climate control scargo W126 S,SE,SEC,SEL,SD,SDL Class 0 12-02-2002 06:03 PM
