DIY W140 moonroof into W126 - Page 8 - Mercedes-Benz Forum
post #71 of 241 (permalink) Old 11-21-2011, 03:41 PM
Grumpy560's Avatar
Date registered: Aug 2009
Vehicle: 1989 560SEL W126, 1989 ford ranger
Back at it tonight, there was mention of rain so I moved some things around in the garage, hooked up a shop light and moved the 560 inside so I could continue this.
I went back and looked over what Snake had mentioned about removing the drip rail(wind deflector)and when I looked closely at the pics I noticed that he had removed it. So I am working on that right now but I am stuck at how to remove it thus far but I will figure it out though I just don't want to break anything.
Here are some pics of the W140 wind deflector and mounting brackets along with what I've had time to do. It's a mess right now.
Oh and Snake, it is the driver side accordion lower metal rail that I am missing, I could not find it anywhere in or around the S500 at the yard and do not see a part # on the other side to go by.
ID:	410870   Click image for larger version
ID:	410871   Click image for larger version
ID:	410872   Click image for larger version
ID:	410873   Click image for larger version
ID:	410875   Click image for larger version
ID:	410876   Click image for larger version
ID:	410877   Click image for larger version
ID:	410878   Click image for larger version
1989 560SEL
702 Smoke silver
Grumpy560 is offline
post #72 of 241 (permalink) Old 11-21-2011, 05:38 PM
Grumpy560's Avatar
Got the W126 drip rail assembly removed and the area cleaned up. I laid the W140 drip rail in place and set the glass top in and the drip rail stands too tall in the W126 sunroof cartridge, panel sticks up about a 1/4 inch so I believe the W140 cartridge has a deeper pan than that of the W126.
I am once again trying to remove the pins from the slider. Snake, witch way did you push yours out. There is a roller wheel on the outside edge that will need to be transferred onto the W140 rail I assume. I will need to repair the W140 rails before I can install them anyway. Each rail has a broken rivet and the keeper is about to come off. Now I see why the sunroof was caulked shut on the S500, everything was shattered.
ID:	410926   Click image for larger version
ID:	410927   Click image for larger version
ID:	410928   Click image for larger version
ID:	410929   Click image for larger version
ID:	410931   Click image for larger version
ID:	410932   Click image for larger version
ID:	410933   Click image for larger version
1989 560SEL
702 Smoke silver
post #73 of 241 (permalink) Old 11-21-2011, 08:00 PM Thread Starter
Solid Snake's Avatar
Date registered: May 2009
Vehicle: 1987 560SEL, 1999 E55 AMG
Quoted: 13 Post(s)
Send a message via AIM to Solid Snake
I am once again trying to remove the pins from the slider. Snake, witch way did you push yours out. There is a roller wheel on the outside edge that will need to be transferred onto the W140 rail I assume. I will need to repair the W140 rails before I can install them anyway. Each rail has a broken rivet and the keeper in about to come off. Now I see why the sunroof was caulked shut on the S500, everything was shattered.
I was able to use the W140 drip rail fine... I used the entire arm assembly though; maybe that's where we differ?
From your pics, it looks like the pins are already out; try pulling them apart! They were nail shaped pins that went through the openings you showed pics of...
I also don't recall my roof having those pieces that are riveted on; Mine was from a 1998. I'll check out the PN tomorrow for you... It'll come together!
1987 560 SEL- 252,xxx Miles
1998 E55 AMG- 81,xxx Miles
Solid Snake is offline
post #74 of 241 (permalink) Old 11-21-2011, 08:26 PM
Grumpy560's Avatar
Well I tried to get those pins out but no luck, so I decided to try some of my own mods. I took a good look at both W140 and W126 rails and the back portions where the pin goes are in fact identical. So what I did was took the outer W140 rail, unbolted that from the inner(mounts to sunroof panel)and cut the rear half off and bolted the front portion of the rail back to the inner rail. I then assembled everything back onto the tracks.
I took the advantage of cleaning up in there some and then I installed the glass panel, made a few adjustments and it was in working order, not perfect but it works. The keepers for the sliding cover catch when the roof is opened all the way so I have to be careful until I get the shade installed. I went for a short drive down the road to see how the wind noise was going to be but since I have most of the interior out and the 560 is crammed full of parts so I really couldn't tell much of a change.
I still need to make some adjustments but I think that is going to wait until I get some sunroof paste because everything will have to come back out.
Thanks Snake for all the help you have given here and I am sure that others will most likely be doing this.
ID:	410966   Click image for larger version
ID:	410967   Click image for larger version
ID:	410968   Click image for larger version
ID:	410969   Click image for larger version
ID:	410971   Click image for larger version
ID:	410972   Click image for larger version
ID:	410973   Click image for larger version
ID:	410974   Click image for larger version
1989 560SEL
702 Smoke silver
post #75 of 241 (permalink) Old 11-21-2011, 09:05 PM Thread Starter
Quoted: 13 Post(s)
Wow you really went all out! The W140 arms fit right into the existing rails you switched out! Check em, they have W126 part numbers. All in all, I think it's totally worth the effort to retrofit; hopefully you get your sliding headliner refinished as soon as I do! I sure hope the club grows!
post #76 of 241 (permalink) Old 11-21-2011, 09:28 PM
Grumpy560's Avatar
Yep, like you said Snake, they will work but for some reason mine were different and my W126 rails at the rear were held in by pressed in pins, all metal rails back there too, strange though. anyhow I got the glass top mounted and it fits in there perfectly like you said although I will need to replace the sunroof seal but dude that's going to be a job for someone else, I'm not touching it!!!
I have the sliding shade and the shell is perfect but the upholstery has seen it's share of abuse so it will need to be recovered as yours does, however I plan on doing mine myself. I am going back to the yard to see if the headliner in the 88 300SEL is the same color as mine or close to it, if it is then I will remove it and use that to recover my sliding shade.
1989 560SEL
702 Smoke silver
post #77 of 241 (permalink) Old 11-21-2011, 10:04 PM
Premium Member
Dr.Grillz's Avatar
Vehicle: Mercedes
Quoted: 240 Post(s)
I'm going to join this "club" as I've always wanted a glass sunroof but thought it was not possible without having a custom one made. Now that an original Mercedes part can be used, I will be gathering parts for this future project.
Thanks for all the detailed info and pictures guys!
1980 Mercedes 280TE AMG
1989 Mercedes 560SEC
1990 Mercedes 560SEL with AMG parts modifications
1991 Mercedes 190E AMG with Brabus 4-cyl M102 2.6
Dr.Grillz is offline
post #78 of 241 (permalink) Old 11-21-2011, 10:37 PM Thread Starter
Quoted: 13 Post(s)
Seriously pay the guy to do it. I want to shoot myself in the foot for trying to rivet the rear part on. I easily wasted 10 rivets because you have to half squeeze then full squeeze the rivet gun for proper clearance. And it STILL isn't right. UGH.
The only problem with the W126 headliner material is it is split into two parts for the tilt function. The vents are removable as well as handle from the W140 shade, which is made of a fiberglass or resin type material. Scraped off the old stuff and I just have to uncover my W126 one and wrap the W140 one So much to do, so little time!
Congrats on the install, you're gonna love the illusion of more space while driving. I hadn't had a working roof, that's why I jumped at the trial. Thankfully it paid it's dividends!
post #79 of 241 (permalink) Old 11-21-2011, 10:38 PM Thread Starter
Quoted: 13 Post(s)
Absolutely! If you need any help obviously hit me up!
post #80 of 241 (permalink) Old 11-22-2011, 03:44 AM
Grumpy560's Avatar
Yeah, I see exactly how that seal is on there and that's why I am going to leave it to the pro's.
I am not going to use the material from my original sunroof cover, i am going to store that away with the original sunroof panel, instead I will take the rear portion of the headliner from one of the parts cars at the salvage yard if I can find one that is the same as mine.
The glass top sunroof does give more headroom above when the shade is open and I have noticed that.
Yes, it paid it's dividends because now other W126 owners have the option to put a glass top in if they so desire and since I have done it I can attest to it being absolutely worth it. Great job Snake.
1989 560SEL
702 Smoke silver
    w126 vs w140 timsmith54321 W140 S-Class 34 12-06-2012 11:03 AM
    AMG W140 trying to look like an AMG W126! brucemendel W126 S,SE,SEC,SEL,SD,SDL Class 31 02-15-2012 01:22 PM
    W126 v W140 MichiganMan General Mercedes-Benz 0 10-31-2008 07:28 AM
    W126 vs W140 Nightbird W126 S,SE,SEC,SEL,SD,SDL Class 18 09-29-2007 08:54 AM
    W126 to W140 amit1 W126 S,SE,SEC,SEL,SD,SDL Class 9 06-29-2006 07:17 PM
