1986 gen 2 500 SEC, based in the UK, so a Euro model.
As the title says: the headlamps won't turn off. Even with the switch at 0, the lights are still on (although the lights on buzzer only sounds with the switch at 1). This follows on from some work in the fusebox, specifically the addition of a feed from terminal 30 at fuse 15. Any ideas? If I pull the headlamp relay they go out.
All help gratefully appreciated.
