560SEC with 722.6 - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-20-2011, 07:00 PM Thread Starter
tsb220's Avatar
Date registered: Jul 2008
Vehicle: 1987 W126 (M104 swap); 2002 G500; 2005 E500 7G; 1997 S500 Coupe ECE; 2004 S500 7G
Send a message via Yahoo to tsb220 Send a message via Skype™ to tsb220
Lightbulb 560SEC with 722.6
Hello guys! I'm planning to install 722.6 tranny from S500 W140 to my 1988 560SEC ABC Exclusive. Because this 722.3 tranny is old, low torque outputs and very high revs in freeway. There is company "Powertrain Control Solutions" PCS can control the 722.6 tranny. Any ideas?
tsb220 is offline
post #2 of 14 (permalink) Old 06-20-2011, 07:25 PM
bondavi's Avatar
Date registered: Sep 2004
Vehicle: 1984-2005 MB's
Quoted: 520 Post(s)
What rear end ratio does your SEC run? If you don't know, tell us the RPM's at 60MPH in top gear.
bondavi is offline
post #3 of 14 (permalink) Old 06-20-2011, 07:36 PM
akimball442's Avatar
Date registered: Nov 2007
Vehicle: '73 450SL, '83 300CD, '01 E320 4matic
Quoted: 10 Post(s)
Does the 722.6 have overdrive? This could be interesting.
-Aaron
ASE Master tech, specializing in electronics and driveability.
Certified Diesel Master tech.
EPA 609 certified
2001 E320 - 4matic - daily driver
1973 450SL - 191K - Summer Toy
1983 300CD -170K
1989 300SE - on to the next owner
1981 Coupe DeVille.. just because.
1983 Chevy Suburban Diesel... workhorse.
... and many more past and present...
Because Safety is not a luxury. Mercedes-Benz. Engineered like no other car in the world.
akimball442 is offline
post #4 of 14 (permalink) Old 06-20-2011, 07:41 PM
roncallo's Avatar
Date registered: Apr 2005
Vehicle: 1986 560SL with M120 V12 Engine, 1988 560SL Stock
Quoted: 295 Post(s)
I think its a great idea. I installed the M120 V12 engine and 722.6 trans into my 560SL. The 722.6 alone makes the car really nice. I have increased my gas mileage by about 15% by putting this engine and trans in over the M117/722.3. I belie most of the gas mileage increase is due to the new trans with lockup converter and over drive 5th.
I have heard the 722.6 from the early M119's will bolt directly to the M117 with 2 bolts that wont line up but can be left out???. You may get away without shortening your drive shaft and the trans output flange is available in both 3 and 4 lobe.
The PCM controller does not exactly sound plug an play to me I understand it is a solution.
roncallo is offline
post #5 of 14 (permalink) Old 06-20-2011, 08:59 PM
mclare's Avatar
Date registered: Aug 2008
Vehicle: 2012 CL550 4MATIC Coupe
Quoted: 252 Post(s)
Send a message via Yahoo to mclare Send a message via Skype™ to mclare
I have been pondering the same thing, but with the addition of Paddle Shifting which would really lend itself better to that tranny. I've got the PS part all worked out, that's easy. It's just making the .6 talk to the car, or rather make the car talk to the .6. From what I understand, the 126 lacks the necessary control inputs. If you want to talk about it, PM me and lets collaborate if you want. I will be following your progress with great interest.
Best of luck!
Current Stable:
1990-560 SEL - Sedan - 199/261 - Stock. Euro Headlamps & Wipers FOR SALE. - PM ME
Past cars:
1991-560 SEC AMG - Coupe - 199/261 - 300 HP Custom Built Motor - Highly Modified Coupe.
1987 560 SEC Black/Tan
1988 420 SEL Champagne/Brown
mclare is offline
post #6 of 14 (permalink) Old 06-22-2011, 02:49 PM
lahiru's Avatar
Date registered: Oct 2008
Vehicle: 1989 mercedes 420 sel & 1995 volvo 850 t5 (just in case)
Quoted: 5 Post(s)
well according to this a 126 certainly does have a TPS:
http://www.benzworld.org/forums/w126...on-sensor.html , which is one of the important inputs in controlling the transmission. maybe that could be tapped (in Parallel) into in for the signal to the PCM (powertain control module).
but it may need other other inputs such as a topographical sensor, RPM, Vehicle speed (possibly from ABS).
Not sure what else I'm missing.
lahiru is offline
post #7 of 14 (permalink) Old 06-23-2011, 07:52 AM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 16 Post(s)
Send a message via AIM to jhodg5ck
The PCS controller is Good but it requires a LOT Of programming which is very time consuming. If you head over to PeachParts, find the user whipplem104, see if he'll sell you an already programed PCS control unit, @ least this will have you Well on the way to shifting OK out of the box.
That aside, I bolted up a .6 bell-housing to a 560 the other day, lined up beautifully..
a .6 would IMHO, be the perfect addition to these cars, couple that w/ forced induction via a pair of GT28's, stand alone fuel & spark....hmmmmmm...
Or, "just" put a V12 in like John;-)
jono
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #8 of 14 (permalink) Old 05-16-2015, 09:27 AM
KRH
KRH's Avatar
Date registered: Nov 2009
Vehicle: 87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Quoted: 382 Post(s)
I think putting a 722.620 trans behind a M117 is a very do-able mod without much fuss
The PCS Trans Controller Unit is a smart solution to running the trans and i now have one of those units to play with
Powertrain Control Solutions | PCS | Sound German Automotive
I also noticed also recently this guy in Europe is all over the 722.6 trans with his own similar control unit which is plug and play
Take you time to watch his "many" Youtube clips on the subject and take a look at the instructions link below as well - his various video clips explain a lot of technical info in great and clear detail
He even provides a kit to adapt to your tailshaft to run the W126 ABS and also mods on how to run your speedo as well in the instruction manual link below
Enjoy
New 722.6 Gearbox in you old Car | Mercedes-Benz turbo
https://docs.google.com/document/d/1..._LuAQHUNI/edit
EuroMerk likes this.
<a href=https://flic.kr/p/TFzygw target=_blank><img src=https://c1.staticflickr.com/3/2875/33922085756_33ce87aec9_m.jpg border=0 alt= /></a><a href=https://flic.kr/p/TFzygw target=_blank>Avatar</a> by <a href=https://www.flickr.com/photos/krh2013/ target=_blank>Kim</a>, on Flickr
87 White Euro 500 "ECE" 265hp SEC
88 Black Euro 560 "RUF"300hp SEC
89 Blue Euro 560 "RUF" 300hp Hydro SEL
https://www.flickr.com/photos/krh201...57668572599252
http://www.flickr.com/photos/krh2013...7632548663623/
KRH is offline
post #9 of 14 (permalink) Old 05-22-2015, 04:35 AM
Date registered: Aug 2011
Vehicle: Diesels om616 -> om606
Quoted: 58 Post(s)
Enjoy
Yep, Ole Fejer is a good guy, his controllers work out of the box,
what you need is a sensor to the throttlelinkage, so the controller knows how much power you want from the engine, aswell as a boostsensor if you have a turbo.
the options is endless, if you have aftermarket controller for the engine, the gearbox controller can send a signal to that to stop acceleration/WOT while shifting etc.
his mail is in the link to googledocs there, and his support is good, his controller will make the gearbox "stronger" than stock since you can increase pressure.
Daily: w123 om602 7.5mm 200whp
special/projects/storage: 20 cars +
mbturbo.com
swampmonkey is offline
post #10 of 14 (permalink) Old 05-22-2015, 05:19 AM
Date registered: Mar 2010
Vehicle: 1991 560SEL, 1981 300SD
Quoted: 58 Post(s)
I'm running the PCS controller and so far very happy with it. If you get it from Sound German Automotive, it's pretty much a complete kit with the needed sensors. I have a thread in the performance section of the other forum detailing the install.
Ich liebe meine Autos!
1991 Mercedes-Benz 560SEL | Megasquirt MS3-Pro | 722.6 transmission w/ AMG paddles | Feind Motorsports Sway Bar | Stinger VIP Radar | AntiLaser Priority | PLX Wideband O2 | 150A Alternator | Cat Delete | Nitrous | Twin Turbo - in progress
1981 Mercedes-Benz 300SD | Blown engine, rebuilding someday...
1981 Mercedes-Benz 300SD | Rear ended, retired in garage.
2009 Yamaha AR230HO | Das Boot
Excessive speeding? It ain't excessive till I redline!
300SD81 is offline
Anyone looking for a 560SEC? brucemendel W126 S,SE,SEC,SEL,SD,SDL Class 28 02-08-2010 08:50 AM
87 560SEC AMG value markusfmeyer W126 S,SE,SEC,SEL,SD,SDL Class 31 12-12-2009 10:24 AM
560SEC AMG headers turned out to be for 500euro: will they fit on US spec 560SEC? cascade W126 S,SE,SEC,SEL,SD,SDL Class 25 06-21-2008 09:39 AM
First 560SEC theawp W126 S,SE,SEC,SEL,SD,SDL Class 5 01-18-2008 08:39 PM
My 560SEC opentec W126 S,SE,SEC,SEL,SD,SDL Class 4 09-27-2004 06:42 AM
