Symptoms 560SEL Fuel Pressure Regulator? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-25-2011, 10:55 AM Thread Starter
JamesDean's Avatar
Date registered: Jan 2005
Vehicle: 93 190E 2.6; 82 300 SD Turbo
Quoted: 58 Post(s)
Hey everyone,
I'm just wondering, what might be some symptoms of a bad fuel pressure reg?
On this 560SEL it has trouble with power while below operating temp and if you stomp on the accelerator, the throttle takes a bit to respond to the demand. However if you accelerate slowly it will climb in rpm fine. Once at 80 and everything warmed up, its fine.
The vent line at the regulator is broken, the nipple is MIA, I can feel a woosh of air coming out the back of the regulator. This makes me think the diaphragm is broken and the unit is not maintaining the needed pressure of 6.5 Bar (I think thats the number)
I dont have any CIS gauges to put on the system so I can't be 100% sure of the pressure. It just seems to want to stall out occasionally. I think this is due to too much fuel, as I recall reading that the FPR is more of a dampener than a "regulator"..
Let me know what you gents think....
Cruise not working? Send me a PM. I may be able to help/fix it. Check here for compatibility, tips, diagnostics, component locations, and availability!
1982 - 300SD 144,000
1982 - 300SD 270,000
1989 - 420SEL 210,900
1989 - 560SEL 115,500
1990 - 300SE 263,000
1990 - 560SEL 156,000
1993 - 190E 3.0 225,000
1993 - 300E 191,000
JamesDean is offline
post #2 of 11 (permalink) Old 02-25-2011, 12:50 PM
Benznoob26's Avatar
Date registered: Jul 2009
Send a message via AIM to Benznoob26
Bad fuel pressure regulator swell up oil filters.
Benznoob26 is offline
post #3 of 11 (permalink) Old 02-25-2011, 04:45 PM
Aspect's Avatar
Date registered: Jun 2004
Vehicle: w126
Quoted: 39 Post(s)
That's odd. If the diaphragm ruptures fuel will leak from that vent line. That's a potential hazard if the vent line isn't intact.
It actually is a pressure regulator. You don't really need a CIS gauge setup to test the system pressure. You can use any gauge that reads up to 100PSI. The system pressure is checked at the cold start injector/valve port on the fuel distributor. It should be ~95PSI IIRC. The system pressure should be constant at all load conditions, hot or cold.
The dampener (accumulator in MB speak) is part of the fuel pump/filter assembly. It cushions the pulsing from the pumps. It also quiets the pump(s) operation to some degree. The diaphragm in the accumulator can rupture. That could conceivably result in a decreased system pressure. That could also cause hard starting after the car sits for some period. It's installed inline between the fuel pump(s) and pressure regulator.
There's a temperature sensor for the CIS system. That functions to enrich the fuel mixture according to the engine temperature. Is the economy gauge indicating anything unusual?
Aspect is offline
post #4 of 11 (permalink) Old 02-25-2011, 05:01 PM Thread Starter
JamesDean's Avatar
Quoted: 58 Post(s)
Hmm, I'll have to see if I can get a gauge/find a fitting to get to that cold start injector and verify system pressure.
The economy gauges goes to 50% sometimes when the engine is just started and not at OP temp, If you leave it idle, it'll walk down to 0 and stall out... once the engine is up at normal temp the gauge runs normal.
1993 - 300E 191,000
post #5 of 11 (permalink) Old 02-25-2011, 06:27 PM
Date registered: Mar 2010
Vehicle: 560SEC, 190E, Frontier, 240Z
Quoted: 16 Post(s)
You can get some idea of what your fuel pressures are doing with the Duty Cycle reading at Idle and at 2500rpm.
Might as well replace that DPR and see how it goes.
Probably get one pretty cheap?
TJ
Tom Johnson, Phoenix, Az
2010 C350
1988 560SEC
1993 190E-2.6
1973 240Z (Track only)
2003 F350 7.3
tjyak50 is offline
post #6 of 11 (permalink) Old 02-25-2011, 06:47 PM Thread Starter
JamesDean's Avatar
Quoted: 58 Post(s)
DPR? I found a replacement (used) FPR on ebay for like $35
Mike told me the car is reading 5%-15% at idle for duty cycle...not sure about 2500rpm though...
1993 - 300E 191,000
post #7 of 11 (permalink) Old 02-25-2011, 06:50 PM
Quoted: 16 Post(s)
TAke a picture of what is broken?
5-15% DC is a sure sign of a problem.
Question is where exactly.
My I wouldn't mess with adjustments until you nail the cause of 5-15%.
2010 C350
1988 560SEC
1993 190E-2.6
2003 F350 7.3
tjyak50 is offline
post #8 of 11 (permalink) Old 02-25-2011, 07:48 PM Thread Starter
JamesDean's Avatar
Quoted: 58 Post(s)
a picture of the broken piece of the fpr?
http://i187.photobucket.com/albums/x...1/DSC_0122.jpg
on the back of it that is supposed to be a vent tube that gets fed back into the valve cover..thats not the unit from the 560SEL, but it the same...
5-15% might be the result of some adjustments...I remember we adjusted lambda and when the mixture was near the 50s the idle was higher than we liked like 800rpm at idle..or something like that..it was few weeks ago I'm not remembering clearly
1993 - 300E 191,000
post #9 of 11 (permalink) Old 02-25-2011, 09:21 PM
Quoted: 16 Post(s)
Idle RPM is not a variable in CIS-E like we have.
It is fixed at the MB value or else it is AFU (see threads for High-Idle).
DC needs to be 50% at idle. It is important to make sure you have your DVOM probes correct so that pushing down the airflow plate momentarily enriches mixture and the DC should go Down (Lower %). Right or wrong, that is how I interprete the manual. Its a way to determine we are all using the same reference.
If you show 5-15% (call it 10% Average) you are very rich and the system is doing 90% of its total capacity to keep over-rich mixture in Control (14.7 AFR). When you add throttle the airflow plate causes over-enrichment due to exceeding the control range. Might cause flubbing and hesitation.
If you have your DVOM Probes backwards and in fact you are Super lean and when you tip in throttle the car will fall flat on its face. Aint got no gas.
The CIS-E is a Lambda (14.7) governor and has a limited control range. When I say "Rich" or "lean" but you are still reading some percent DC between 10% and 90% you are still 14.7 AFR but the system is nearly maxed out and any addition increaese or decrease in fuel takes you out of the control range of 14.7 and you will see DC infinitely 0 or 1 out of the range.
I spent a year learning this system by hard knocks and have my hands comfortably around it now. I have 50% average at idle and 35% or so at 2500RPM. THis puts me a shade on the too rich side at Wide Open Throttle by reference to my WB/O2 sensor and dyno runs. Just where I want it.
Hope I can help and return the favor to those that helped me. Its a tricky little system.
Tj
2010 C350
1988 560SEC
1993 190E-2.6
2003 F350 7.3
tjyak50 is offline
post #10 of 11 (permalink) Old 02-27-2011, 12:25 PM Thread Starter
JamesDean's Avatar
Quoted: 58 Post(s)
Tj
I know the idle rpm isn't adjustable. It was just a side-effect we noticed when we adjusted the lambda tower.
I'll adjust the lambda so that its near 50% at idle. Any problems in idle, I can assume is being caused by something else?
1993 - 300E 191,000
    Fuel pressure regulator DAVECAD2.0 W126 S,SE,SEC,SEL,SD,SDL Class 0 11-16-2010 10:18 AM
    fuel pressure regulator garysalas W126 S,SE,SEC,SEL,SD,SDL Class 1 04-27-2010 04:24 PM
    fuel pressure regulator travis04240 W201 190-Class 1 12-22-2008 06:04 PM
    Fuel Pressure Regulator rmt6668 W202 C-Class 9 12-01-2007 12:07 AM
    Fuel Pressure Regulator? graystarr W201 190-Class 1 11-19-2007 03:06 PM
